J2Racing Posted December 13, 2011 Share Posted December 13, 2011 Does anyone know of a bolt option for power steering in an HQ holden. Yes I realise factory stuff will bolt in but it is proving hard to find. I was think early commodore ie VB to VK. A cert is not an issue as car will need it for the chev going in. Quote Link to comment Share on other sites More sharing options...
shizzl Posted December 13, 2011 Share Posted December 13, 2011 if you want hq p/s bits try macgors...alot of stockcar guys run them i had hq stuff in mine... you can buy brand new GM pumps for them through rare spares and segedins etc, its the p/s box thats the hard bit to get. again try rare spares... i wouldve thought that commys had rack and pinion? Quote Link to comment Share on other sites More sharing options...
cletus Posted December 13, 2011 Share Posted December 13, 2011 yea commodores are all rack converting to rack will be a headache. you could try pg hydraulics in east tamaki ,auckland for a reco box Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted December 13, 2011 Share Posted December 13, 2011 As Paul has said, Commodores are rack and pinion. The pre-commodore holdens used a steering box setup. The easiest way would be to fit the power steering setup from another HQ-HZ into your car. Does anyone know of a bolt option for power steering in an HQ holden. Yes I realise factory stuff will bolt in but it is proving hard to find. Keep trying, you'll find it eventually. It's by far the best option for what you want. Scroll down to question three: http://www.trademe.co.nz/Browse/Listing.aspx?id=430306851 Quote Link to comment Share on other sites More sharing options...
CUL8R Posted December 13, 2011 Share Posted December 13, 2011 Perhaps use falcon or datsun 260c power steer box, they're a common conversion for alot of cars & used in stockcars alot (read: strong) Quote Link to comment Share on other sites More sharing options...
shizzl Posted December 13, 2011 Share Posted December 13, 2011 if your gonna piss around with modding something to fit you may be alot better off trying to fit a hilux surf or terrano box,alot easier to get hold of and usually alot less fucked. falcon boxes blow seals when the get old,hilux boxes arent as old,but if you get one check the pitman arm spline cos if its been in a crash the shaft will have twisted...ive used some of those in a stockcar...they run sweet on the GM pumps too.. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted December 22, 2011 Share Posted December 22, 2011 Complete Power steering setup (absolutely everything except the power steering belt) for an HQ-WB (253-308 setup) http://www.trademe.co.nz/motors/car-parts-accessories/holden/accessories/auction-433629446.htm Quote Link to comment Share on other sites More sharing options...
R100 Posted December 23, 2011 Share Posted December 23, 2011 When i converted my hq to power steering i had alot of trouble finding a factory power steer pump etc. So i just bought another complete HQ holden kingswood, and swapped out the power steering with my manual box then sold the car again for the same price. End result = free power steer. 1 Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted December 23, 2011 Share Posted December 23, 2011 Complete Power steering setup (absolutely everything except the power steering belt) for an HQ-WB (253-308 setup)http://www.trademe.co.nz/motors/car-parts-accessories/holden/accessories/auction-433629446.htm Also here: http://www.trademe.co.nz/motors/car-parts-accessories/holden/steering/auction-434587129.htm Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted December 24, 2011 Share Posted December 24, 2011 i did a conversion into a HQ using factory steering box and a electric mr2 pump, didn't like the ulgy pump on the motor 1 Quote Link to comment Share on other sites More sharing options...
Steve74 Posted April 30, 2016 Share Posted April 30, 2016 Sorry for dredging up an old topic. I have an HQ 6cyl that I want to fit power steering to, trouble is I'm not sure how many of the steering components need changed. I know the following: Power steering box - have one Power steering pump - hoping the vb commodore one I have can be used Pump hoses - will get generic items made or buy second hand Double pulley - have one Pump bracket - hoping I can adapt the vb commodore one or make one Belts - easy found locally Pitman arm - will need to find Shaft coupling - will need to find What else will I need to find and swap out??? Cheers Steve Quote Link to comment Share on other sites More sharing options...
