HighLUX Posted May 6, 2012 Share Posted May 6, 2012 I have a JZ loom ecu and throttle body bit your welcome to have Quote Link to comment Share on other sites More sharing options...
EURON8 Posted May 7, 2012 Author Share Posted May 7, 2012 That would be lush man. Will sort transit later tonight Quote Link to comment Share on other sites More sharing options...
HighLUX Posted May 7, 2012 Share Posted May 7, 2012 The loom has seen better days and is missing the injector plugs but could be hoki'd to run/catch fire easily enough. ECU/throttle body are from 1jz with TRC Quote Link to comment Share on other sites More sharing options...
EURON8 Posted June 6, 2012 Author Share Posted June 6, 2012 Semi-picture-less update: Got a spare set of strurts , (chur boxxy) Stripped them down tonight. Made a bit of a mess when i learnt that the strut tube was part of the shock and not just incasing an insert. Tested coilover on strut tube and bam !! Prefect fit. No measuring or research was done prior to buying the coilovers. When i weld them together what overlap distance would you guys recommend? The hole you can see is approx 60mm from the bottom. Engine bay is fully stripped now. starting to clean all the grease off ** Oven cleaner+10mins+scourer pad+warm water and rag = super clean. (Disclaimer: Will be repainting so dont know how this would work on kept/good paint) Engine updates: Acquired 2JZ (Chur ryanfels) Acquired loom,ecu,throttle body (Chur highLUX) Soon to acquire the required 2JZ parts the engine is missing (Chur Neo12345) Friendly CAD doodler required for engine mounts and ITB manifold :wink will take some pretty pictures when if can get home before it gets dark. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted June 6, 2012 Share Posted June 6, 2012 hey hey hey this manifold for the ITB's you making to suit a 2jz yes?? I maybe keen. Quote Link to comment Share on other sites More sharing options...
EURON8 Posted June 6, 2012 Author Share Posted June 6, 2012 Yup 6 silver top itbs to 2jzge head. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted June 6, 2012 Share Posted June 6, 2012 Mmmmmm itbs, nummy. Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 6, 2012 Share Posted June 6, 2012 what are the coilovers off? that pic is awesome looks like you got some random rusty pipe to fit over your strut Got someone to cad your stuff? if you have a photocopier thingo at work (mrs will if you dont) scan the shit out of what you need made and measure the shit out of it. Should be a bunch of people who can help, I can at last resort What ECU will you be using for the ITB setup? Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted June 6, 2012 Share Posted June 6, 2012 I have cad stz. Gizz details and I will give you .dxf's .dwg's/whatevfer you want. Quote Link to comment Share on other sites More sharing options...
EURON8 Posted June 7, 2012 Author Share Posted June 7, 2012 what are the coilovers off? that pic is awesome looks like you got some random rusty pipe to fit over your strutGot someone to cad your stuff? if you have a photocopier thingo at work (mrs will if you dont) scan the shit out of what you need made and measure the shit out of it. Should be a bunch of people who can help, I can at last resort What ECU will you be using for the ITB setup? I believe they are ex Subaru. I brought them with the bottom sleeve already trimmed drilled and ground/grinded. Got some measuring and doodling to do before I'm ready for stz to be cut. Mega squirt to run it. I have cad stz.Gizz details and I will give you .dxf's .dwg's/whatevfer you want. Chur will let u know if infant find someone locally. Maybe Mikey will trade drawings for the welding I'm doing for him Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted June 7, 2012 Share Posted June 7, 2012 Just pm me if you do want anything drawn up, I have access to solidworks and inventor etc and mounts will take piss all work for me. Both will be reso easy to smash out in a lunchtime etc. Same goes for anyone tbh. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted June 7, 2012 Share Posted June 7, 2012 Can you smash me out in your lunch time? wink wink. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted June 7, 2012 Share Posted June 7, 2012 Shouldn't need to make mounts if the standard ones are anything like cheerios? Quote Link to comment Share on other sites More sharing options...
slacker.cam Posted June 7, 2012 Share Posted June 7, 2012 The other option is just buy the correct crossmember to fit your motor. http://www.trademe.co.nz/motors/car-par ... 667691.htm Seems pricey but I know nothing about this JZ buisness. Sounds like youve got CAD stuff sorted but I can help if that doesn't work. Quote Link to comment Share on other sites More sharing options...
EURON8 Posted June 7, 2012 Author Share Posted June 7, 2012 Yeah the price of jzx crossmember and mounts is why I'm just gonna make some. Plus I can make em look prettier than stock Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 7, 2012 Share Posted June 7, 2012 OS needs a sweet CAD file thread for mounts and intake flanges! Quote Link to comment Share on other sites More sharing options...
mikuni Posted June 7, 2012 Share Posted June 7, 2012 OS needs a sweet CAD file thread for mounts and intake flanges!Yes! How many times have people asked for bloody 20v flanges! I'm keen for some but lazy and need blacktop Quote Link to comment Share on other sites More sharing options...
Truenotch Posted June 7, 2012 Share Posted June 7, 2012 The ones Cheerio's casting could work with your crossmember. Quote Link to comment Share on other sites More sharing options...
peteretep Posted June 7, 2012 Share Posted June 7, 2012 me and chris talked about library ages ago but we are obvisouly too lazy to go any further I wonder if I am the only person on earth to have an inlet flange in 3d and 2d cad for a 1300 motor in an 808 haha Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 7, 2012 Share Posted June 7, 2012 Haha possibly! I'll make a thread, sticky it and it can be a place for possible requests aswell. Quote Link to comment Share on other sites More sharing options...
