kicker Posted March 22, 2012 Author Share Posted March 22, 2012 Scored a new seat which actually has some cushioning in it unlike the previous one, got some footpegs ready to go on and have a front pulley ready to be machined Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted March 22, 2012 Share Posted March 22, 2012 ^ I must say, this is my fave velo bike, bloody top job. Quote Link to comment Share on other sites More sharing options...
kicker Posted March 23, 2012 Author Share Posted March 23, 2012 Cheers man, hopefully have it done soon, I tend to take too long thinking about different ideas and waiting for parts/inspiration but I'm happy with how it looks just need to make it go now. I think I have fixed the erratic idle now too, the engine vibration would move the slide up an down in the carb making it rev/stall when you didn't want to so I put a spring from a bic pen on top of the slide (I assume there is supposed to be one, there is a hole it sits in, the old duffer who owned must have taken it apart and lost a few bits) and that now holds it in the position you set it at with the throttle. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted March 24, 2012 Share Posted March 24, 2012 yeah there are generally springs on top of the slide, how did you manage to get the slide returning to closed without it? gravity/magic/luck? Quote Link to comment Share on other sites More sharing options...
DodgySam Posted March 24, 2012 Share Posted March 24, 2012 Magic...always magic...its the OS way! Quote Link to comment Share on other sites More sharing options...
kicker Posted March 24, 2012 Author Share Posted March 24, 2012 Gravity was enough to drop the brass slide down again but the vibes would make it shimmy up and down. The first thing I noticed was a lack of a spring, that and some spacers which were causing slackness in the cable, it must have been a pain in the arse when it was still a reel mower, speeding up randomly haha I might keep the throttle where it is currently located just in front of the seat (yeah suicide throttle) and use a foot clutch, would be cool to have no controls on the bars Quote Link to comment Share on other sites More sharing options...
rot808 Posted March 24, 2012 Share Posted March 24, 2012 lols at throttlecrotch holding while speeding around velodrome, please do this Quote Link to comment Share on other sites More sharing options...
Guest kicker Posted April 16, 2013 Share Posted April 16, 2013 This is a bit out of date so here are some pics. Here is where it got to in its first incarnation with the Atco engine Then I got some of these and decided to put two in for dromageddon As it was at the end of dromageddon. twin throttle levers, big air leak in rear engine inlet, belt tension bodge, loose and wrong size chain but other than that it ran good I got the air leak fixed but with the current gearing it'll only do 50kph flat but seems happy to do it all day, I ran out of gas after 40 laps last time out. I picked up a smaller rim recently to change the gearing, I'll find out soon if it'll work or not. The new throttle setup with twist grip and today I made a unneeded bracket for the cylinders and fired it up for some two stroke aromatherapy Quote Link to comment Share on other sites More sharing options...
Guest KIRK Posted April 16, 2013 Share Posted April 16, 2013 how u guna attach the little rim to the spokes on the big one? Quote Link to comment Share on other sites More sharing options...
Guest kicker Posted April 16, 2013 Share Posted April 16, 2013 was gonna either make some brackets and attach small rim to big rim or just cut some sheet metal into a circle and weld them up. might just go the sheet metal route, will be easy with a jigsaw and should be concentric enough Quote Link to comment Share on other sites More sharing options...
Guest KIRK Posted April 16, 2013 Share Posted April 16, 2013 wouldn't it be easier to put bigger pully on the lay shaft? Quote Link to comment Share on other sites More sharing options...
Guest kicker Posted April 16, 2013 Share Posted April 16, 2013 It's a bit toight for space there, wouldn't want to go much bigger plus rims are cheap Quote Link to comment Share on other sites More sharing options...
Guest KIRK Posted April 16, 2013 Share Posted April 16, 2013 oh yur. yeh I seen your can buy kits kinda like that with lots of little brackets that bolt the rim to the spokes. dunno how strong it is/how long until spokes get ripped out. something like this I reckon is better? Quote Link to comment Share on other sites More sharing options...
Guest Steelies Posted April 16, 2013 Share Posted April 16, 2013 ^that's what danny has done on his boardtracker, worked really well. kickstart, choice Quote Link to comment Share on other sites More sharing options...
kicker Posted April 24, 2013 Author Share Posted April 24, 2013 I've got one of those kick start setups floating around, could be the answer if I directly link the engines. Anyhoo Need some new belts now Anyone know where I can get some 6~mm OD copper pipe in Wellington? I want to use some to tidy up my fuel lines, might try the brew shop in Newtown 1 Quote Link to comment Share on other sites More sharing options...
KIRK Posted April 24, 2013 Share Posted April 24, 2013 steal some out of a broken fridge from a scrap dealer or fridge repair shop maybe/nah. looks cool man Quote Link to comment Share on other sites More sharing options...
73crownwagon Posted April 24, 2013 Share Posted April 24, 2013 i got tones of 6mm copper pipe but in auckland how much u need i can send some down if u like? and Fuck yes back wheel is sick!!!! Quote Link to comment Share on other sites More sharing options...
rot808 Posted April 25, 2013 Share Posted April 25, 2013 back wheel looks sofa king sweet, as does how much more mechanical mass this has now over the single engine overalli pingin az 1 Quote Link to comment Share on other sites More sharing options...
Testament Posted April 25, 2013 Share Posted April 25, 2013 good work, great work! Quote Link to comment Share on other sites More sharing options...
Steelies Posted April 25, 2013 Share Posted April 25, 2013 choice kicker! i should be able to help you on the copper line. Quote Link to comment Share on other sites More sharing options...
