Brennan
Brennan's 54 Chevy kustom
Nope not Steve's lol.
Im considering buying a 1uz, trying it in this to see how it fits. and if it does not look like a easy fit keep it for the cressida??
Chevys of this era only came out with 6 cylinders tho so the v6 isnt so bad :P
Share this post
Link to post
Cant see how this plan could fail!
Share this post
Link to post
Also since it has no room for mufflers or evan exhaust underneath, Im thinking i will run lake pipes,
and was told that turbos muffle the exhaust note by quite a bit so was thinking twin turbo the v6??
Would be a really simple very low boost setup with no intercooler??
Share this post
Link to post
The 3.8 looks soooo small with the body on it, should bolt another 3.8 in there and run it v12 spec.
Share this post
Link to post
Assume you've seen this?
Sorry for wrong thread, on phone and finding is hard.
Edited by AllTorque
moved
Share this post
Link to post
Thanks Kyteler. Yes, That was what started the thought process.
I will be taking a bit longer than 3 months, and spending a bit more on it.
I am also being a lot more careful about how much i cut out.
The biggest worries i have from his, is the diff/subframe needing to move back 2 or so inches.
And the track width being soo wide.
The Renault Espace on the ls400 floorplan helped convince me to give it a go too
http://build-threads.com/build-threads/renault-espace-lexus-ls400/
Share this post
Link to post
11 hours ago, flyingbrick said:
Lack of steel in sills is likely because the roof is/was structural.
Is this going to be on the road here @cletus is this possible?
I guess i was expecting a steel tube, a bit like the side extrusion bars in the doors.
There should be more than enough strength in the chevy body, to make up for what i have removed.
 Will be adding RHS in too, as weight will not be a worry.
Share this post
Link to post
Is doable, I started a job for someone doing the same sort of thing with a mercedes donor and studebaker body, we did a torsional twist test on the donor before he started cutting, the idea was to have no more deflection than the donor started with
The only concern is when you use a body that was designed to have a full chassis, as a monocoque, then its probably not strong enough,  as the body was not intended to be as structural as the lexus body was
But it's not difficult to add some strength as you are building it
Share this post
Link to post
21 hours ago, oftensideways said:
looking good man.  I hope you keep all that body damage as is!
That had not crossed my mind, i have got a couple of replacement panels, and looking at getting a couple more if the us dollar ever improves.
It will be left in oxide red primer for quite some time. I expect it to be fairly rough and mongrel in appearance.
Somewhat along the lines of my brothers pickup, but rougher.
While still keeping it looking like you would expect a slammed kustom 54 chevy to look like. And impossible to tell its on a lexus from the outside.
Still on the fence about two dooring it too. Would make it so much stiffer, welding up the rear doors. But i would need to find some soarer/sc400 doors to allow access to the back seat.
Share this post
Link to post
do you mean soarer seats to allow access?
should be really easy to get your hands on, plus they are pretty comfy seats, but they may not suit the cars style? mk4 supra seats could be an option too. the rear seats in a mk4 are black leather too and awesome deep buckets.
Share this post
Link to post
Yup, Would be uzz30 soarer seats of similar age to the lexus.
Yup, mk4 might be an option, but the back seat should be great in the lexus, and i would prefer the heavier , electric, luxury lexus/soarer front seats.
Have just uploaded some concept photoshops to show what i expect it to look like.
Share this post
Link to post
did 30,000kms in a year in a z30. the seats are great.
photoshops look primo. following with great interest, that hoonigan feature of a similar build proves itll be alot of fun
Share this post
Link to post
