  • Replies 322
mm, was thinking 15x8 with zero offset, as have them on my cressida, so would be alright to test fit, to have something to work with till i buy some more, either Watanabe or a widened steel rim.
the way i see it is, if i get the mx5 subframe in there and it is definitely to wide to work with, then i will shorten it up, and that is no problem to do so.
Haha sweet! That what I wana hear, good luck dude..
Toyota F series diff is what you want.
Shorten a Estima diff or find a 4wd townace/liteace rear diff, the latter is only 30ish mm wider that the original dx diff but a weirdo 4wd 5 stud pattern
yea cheers man, will be going to some wreckers on monday to see what i can find. Someone should sell them on trademe with the altezza lsd already in them, for lazy people like myself.
Last time I was at 4x4 commercial on Keith st they had a 4wd liteace and I bought the front diff. 4.556 ratios in that one though, which would make your car perky but might be a bit high in the RPM on the open road.
Otherwise Whakarongo / Total commercial (owned by the same people as Ace Auto dismantlers) is good too.
Cheers oftensideways, that spoiler looks mean on the ke30! cant wait to see it in person somewhere.
And thanks Truenotch, sounds great, will see what i can do.
