Brennan's Toyota Corolla Beams 3sge Ke70
Brennan
Made new shock mounts for the rear. as they were in the way of the fat dual pot calipers before.
Still waiting on hsd coilovers to arive in the country. Very doubtful they will even show up.
And shes all oiled up and ready to go to the auto electrician, so he can work his magic.
Then it is just to build the driveshaft, fill diff with oil, exhaust and all those other stupid little things that pop up at the end of projects.
  • Replies 118
  • Brennan
    117
Apparently she is all wired up and running with her new link g4.
So should be home waiting for me when i fly home on friday.
Next up is
- Driveshaft
- Rear brake lines
- Find some suspension since it looks like my HSD's are definitely not going to turn up :(
- Sort some bigger vented Discs for the front.
Rear break lines - Done
New home made rear brake discs - Work in progress...
New Speedo Cable - Fitted
Other new reproduction ke70 parts - coming soon?
And anybody after an altezza individual throttle body adaptor?
selling like hot cakes on the trademe. Cheaper for you's
Cheers
Guest Brennan
For those interested. Here are the results for the poll a page or so back.
Should I...
...Remove the factory door mirrors and get some fender mirrors?
60.5% 26
...Leave the door mirrors?
39.5% 17
Total Votes: 43
More updates coming soon hopefully.
Would not recomend buying a house. Whilst trying to build a car.
Guest Brennan
Trying to get started on this again, one of the things i need is a heater/demister for those cold days.
As the factory heater core is to big now that the gearbox tunnel has been raised.
Found these in the UK http://www.demon-tweeks.co.uk/motorsport/cockpit-ventilation/demon-tweeks-lightweight-heater
about $200 NZD
Anybody know anything common that i could find at a local wrecker that would be similar?
suzuki swift or something?
although my corolla wont have a/c. just need basic heater core with built in fan.
Cheers
Right. Scrap that idea. Attcked the factory heater core with the sabre saw and it lost allot of excess ducting on the bottom. But it now fits again. Disappointing as I wanted to buy one I those uk heaters to see what they went like.
Update time again people.
Bottom of the heater. It now fits. Removed a good 3inches
Front of heater. Drilled holes for the cores hoses to poke through towards the cabin instead of through the firewall
Getting some soldering done on it at the moment. Then shall refit it hopefully for the last time.
Brought another heater core, since i stuffed the last one with my roughness.
Had the bends cut of the inlet and outlet and re crimped.
chucked it in backwards with the in and outlets sticking out the holes i cut.
where they use to come out:
Fitted:
Should work alright??
Hopefully be some more exciting updates soon.
Mortgage is eating all my money, so, saving for coilovers is not really going to good.
