  • Replies 191
Looks like a good weekends racing , there's a reasonable field there to drive through.
Do they always run the pro7plus among the mx's (pro7 ?)
Whats the rev limit on the mx5's seems to peel through the revs no problem.
And cheers again for dropping my guards off.
We run within the RX7 grid at the moment. It gives us a home in summer and helps them to fill their grids (series 1's were lacking this round). It means there's always action around the track too.
The MX's top out at almost 8000rpm and get there quite easily. They're only 80kw at the wheels though, so you're not going anywhere in a hurry... The key is to not slow down for corners.
I wish my windscreen was that clear in the rain. :-( Around the 1min 20sec point in your video, I couldn't see a thing, including the track. I took a photo of my interior view after I pulled into the pits, which I'll post in my thread later.
Is Mike Dunn from Envirosafe?
Nah, he's a baker who used to have a green UCOL starlet and is big on Canoe polo.
Brent - don't regret it, you're going to end up with an awesome car. Ours are fun, cheap, easy to build and cheap to run, but the RX7 is still a cooler car :P .
Yep, nearly there. The car is getting a wheel alignment at the moment, and my replacement front bumper has just arrived. I've just got a couple of little refinements to make now, then I'm all set.
Dad's also part way through a second car - $4700 takes it in it's current state with a homologated cage. All it needs is a seat, belts, wheels/tyres and some brake pads to get started. Currently on cut Honda springs and standard shocks, but we can work something out for a set of coilovers.
Managed to extend my lead at Round two of the championship at Manfeild with two wins and a second. Not too bad!
We had rain again... In fact, the races were exactly the same as at Taupo - Dry race one, damp race two and a TORRENTIAL race three. We were unable to see through the mist at various points on the track (such as the back straight) and I was using land-marks that could be seen out the side window for braking and turn-in points.
I've changed the seat and the rear springs since last time. I got a deal on an Racetech Saker seat (thanks to Vivaspeed for helping to acquire) which is more leant back and allows my head to sit a lot lower. My shoulder is now below the door line!
It took a wee bit of getting used to, but it feels normal now and is much more comfortable than the old seat (and safer...).
Here's the video from race 1 - having a great battle with a S1 RX7 that had gear selection issues:
