EURON8s ex- concrete/steel saw powered bike
EURON8
So at the workshop theres always been this old concrete/metal saw covered in dust and looking sad.
I finally decided to do something about it, so i rung the oldman and asked if i could have it for a bike motor. Suprisingly he said yes. Probably assumed it didnt work.
He has a big stihl one he uses for work and it sounds so grunty so i hoped this was the same.
Got it home. after i put a tree branch through the back window of the daily i decided i needed some satisfaction.
Poured some gas outta the hedge trimmers and after a few goes it fired up sweet. Isnt as grunty and 2stroke pop and farty as the bg one we have but who cares.
But i smoked out the driveway and neighbours back yard after a full throttle rev for 30 secs.
  • Replies 47
also on that note. FUCK YES.......
I can see another meet coming up with all these wacky bikes.
I'm planning on a weekend at my olds new batch near otaki / llevin ways some time.
They are like a min from the beach. So keen to get all the powered vally bikes out there and do some high speed racing burt munro spec
So after hoping the 650 was referring to its displacement but knowing it is unlikely i did some researching.
Apparently it cranks about 4.8hp, so ill be looking at increasing this :evil:
General Technical Specifications:
Engine:
Type: Two-stroke, air-cooled, single cylinder.
Bore: 50mm
Stroke: 36mm
Displacement: 71cc
Carburetor:
Tillotson HS175F
Recommended Spark Plug:
Champion RCJ7Y, NGK BPMR7A
Required electrode gap: 0.50mm
Fuel and Lubrication:
Fuel: Unleaded gasoline, minimum 89 RON
Fuel/Oil Mixture Ratio:
50:1 using Partner branded two-stroke oil
25:1 using high quality two-stroke oil for air-cooled engines
Torque settings:
Spark plug: 20N-m
Crankcase screws: 10N-m
Cylinder screws: 10N-m
Clutch nut: 50N-m
Flywheel nut: 20N-m
