1979 lancer spedo accurecy
1stgenlancer
hi guys, i finaly took my 1979 lancer for a cert, it faild, mostly little things. 1 being the accurecy of my spedo, i have a 1.8l turbo cordia motor, 5 speed sigma gearbox, and 14" mags with 195 45 r 14 tyres on them. my lancer was factory 1.2l 4 speed,
my spedo reads
62 at 50 km
88 at 70 km
99 at 80 km
124 at 100 km
any 1 out there know what i can do to make this right????
I imagine your tyres are alot smaller rolling diameter than factory, and also the gearbox switch has probably put it out even further. One of the mitsi nuts on here might be able to help.
edit, assuming the original tyre size was 155 13 (which google says it is), then your new wheels make the speedo 9% out. plus the difference from factory (speedos are never corect), so say an extra 5%, so the best part of 15% error.
probably explains it why your speedo are so far out
Mines the same, tried different speedo gears, dosnt help.its because you are using the sigma box also as they where set up to run a lower diff ratio (3.6 or somthing), where as the lancer is either 3.9 or a 4.2.
if you send it away, they'll need to know how much to adjust it by
using your data, the correction factor would be 1.24 (aka +24%)
50	62	 1.24
70	88 	1.25
80	99 	1.23
100  124	1.24
DIY electronic speedo could be easier/cheaper?
Jaycar sell kitsets for like $50 which can adjust signal frequency.
