EvoBilly Posted May 8, 2011 Share Posted May 8, 2011 thought i would start a talky for this need tips on removing bad smells from inside of car also options of engine i really would like to get the one in it running so i can use it well i find bits to mod sounds like the bore might be caroded thinking head might come off and give it a clean and hone maybe rebuild with new bits otherwise just a couple gaskits and put back together with old bits thinking just going city turbo and engine basically bolts in just have to sort exhaust and loom and if i can get a whole car could swap hubs etc to get 4x100 and get rid of the oddball 4x120 and convert to manual at the same time ive been wanting to have somthing small good on fuel thats turbo that i can put a screamer pipe and go nuts with also tips for lowering this will be after its running but looking for options now and rear seat belts the rat ate them in the civic but my ke30 is 79 and get a wof with none can i just remove all trace of the belts from the rear and get away with it what the wof rule for this? Quote Link to comment Share on other sites More sharing options...
civic_zr Posted May 8, 2011 Share Posted May 8, 2011 City turbo swap is quite straight forward mechanically, engine drops straight in on your factory mounts/mounting points, gearbox bolts up nicely and manual eb civic gear linkages work. Only hard part is wiring. Also helps to run new fuel lines with an external pump. Lower is hard, need shortened shock for any kind of decent drop. Also the 4x100 swap is easy, but finding the wagon hubs you need is hard, theres only a few sets in NZ afaik. Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted May 8, 2011 Author Share Posted May 8, 2011 what bout the other way as mine is hondamatic so i don't have gear linkages will city ones fit the civ? Quote Link to comment Share on other sites More sharing options...
civic_zr Posted May 9, 2011 Share Posted May 9, 2011 Hmmm not sure, I think the city ones are a bit different, but can be modified to work. I've got some civic ones, and a pedal box if you need them Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted May 9, 2011 Share Posted May 9, 2011 Was this up the Waihopai valley? At Bernies? Big posh house surrounded by fields with a little old cottage next to it? If so did ya see the cool line up of old Bedford K series trucks? Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted May 10, 2011 Author Share Posted May 10, 2011 Was this up the Waihopai valley? At Bernies? Big posh house surrounded by fields with a little old cottage next to it? If so did ya see the cool line up of old Bedford K series trucks? no i got this one from koromiko down a long side road but well i was there on the hill i could see a some old looking cars parked up the back of a farm that i want to go back and have a look at but i may have to go for a look see up the waihopai could be good parts car or somthing else hiding all ways keen to find whats hiding Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted May 10, 2011 Share Posted May 10, 2011 Oh ok- well there are two up at this farm in Waihopai. Pretty solid. I'll try and get some more details for ya but its my cousin who lives up there and we have fallen out big style. Quote Link to comment Share on other sites More sharing options...
anglia4 Posted May 23, 2011 Share Posted May 23, 2011 As far as I know, rear seat belts are compulsory for anything newer than 74 Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 23, 2011 Share Posted May 23, 2011 As far as I know, rear seat belts are compulsory for anything newer than 74 I think its 79. Ive had a 75 and a 79 that both gots wofs without seat belts (not dodge wofs as well) Quote Link to comment Share on other sites More sharing options...
KKtrips Posted May 23, 2011 Share Posted May 23, 2011 FYI - its for anything newer than 1st November 79.. edit - beaten by Beaver - he must be learning well. Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted May 23, 2011 Author Share Posted May 23, 2011 so it was first reg sep 1979 so would i be right in thinking if i took the rear belts out and removed all trace then i shouldn't have any issue with wof? Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 23, 2011 Share Posted May 23, 2011 edit - beaten by Beaver - he must be learning well. why thank you master. billy (assuming your name is billy), yes you should/will be sweet Quote Link to comment Share on other sites More sharing options...
KKtrips Posted May 23, 2011 Share Posted May 23, 2011 Correct. edit - fuck it beaten AGAIN!! LOL Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted May 23, 2011 Author Share Posted May 23, 2011 yep name is Billy and cheers now all i need is some sort of system to make it move (motor) and some tyres as the ones on there have good tread but also have cracks in the side walls as big and deep as the tread Quote Link to comment Share on other sites More sharing options...
anglia4 Posted May 23, 2011 Share Posted May 23, 2011 mint... more tread! Quote Link to comment Share on other sites More sharing options...
mjrstar Posted October 16, 2011 Share Posted October 16, 2011 this thing would be superb with an old accord motor, my mate had one back in the late 90s and it was a very simple swap. Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted October 18, 2011 Author Share Posted October 18, 2011 yeah i looked at all the options the old accord engines bolt right up just gotta mod the head mount a little and they look almost the same so your average wof guy would never know and could get away with out cert i was going to do it for a lite eco work runner but to many projects on the go all at once and now that i scored a ke35 that ive wanted for years i want to waste my cash moneys on that more then the other projects thats why im taking offers if someone would like to buy and take over the project its near rust free only bit ive found apart from exhaust is the bottom guard bout a 20c size i think i posted a pic of it the inside cleaned up good i must take some more pics to post and i also brought a eb2 parts car thats rusty and de-reg but runs and drives the guy i got it off was still using it to drive to work and it had been de-reg since bout 98 lol just luck he didn't get cought Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted November 25, 2011 Author Share Posted November 25, 2011 were on a roll now will be posting update over the weekend as it might be driving spec Can someone tell me what oil goes in the hondamatic as there not really auto and the oil that came out was brown lol so was thinking one of 2 things burnt ATF or manual gear oil? just at work at the mo cleaning the wheels they coming up good if i could be bothered could polish them to mirror finish but can't see that happening maybe after the rest of the car is legal Quote Link to comment Share on other sites More sharing options...
plasticdash Posted November 25, 2011 Share Posted November 25, 2011 semi auto Trans will take Castrol TQ95 , dry fill 4.2 L Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted December 1, 2011 Author Share Posted December 1, 2011 can anyone tell me how to test and find the issue with a fuel gauge so how to test the guage and test the sender as there was a rat living in the car that liked to eat wires so think its just the wire somewere maybe Quote Link to comment Share on other sites More sharing options...
