xygtho Posted July 26, 2011 Share Posted July 26, 2011 Ballast or non ballasted coil? Had this problem on an old Falcon years ago. Would run mint for a bit, and shit out for no apparent reason. Fitted ballast resistor to coil, and Bobs your Uncle.... Quote Link to comment Share on other sites More sharing options...
anglia4 Posted July 26, 2011 Share Posted July 26, 2011 it got progressively worse running each time I started it, now she will not start at all. Is it possible that the dizzy clamp is loose and it slowly adjusted the timing till it wouldn't run anymore? Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 26, 2011 Share Posted July 26, 2011 good thinking^. definitely check that and check the timing Quote Link to comment Share on other sites More sharing options...
burrowssj Posted July 28, 2011 Share Posted July 28, 2011 I wait in anticipation for the solution to your problem Felix Quote Link to comment Share on other sites More sharing options...
felixx Posted July 28, 2011 Author Share Posted July 28, 2011 hey man, well 1) the coil I brought was a non ballasted one, apparently it needed a ballasted coil. (although the original one wasnt) so there was not enuff juice to get a good spark. 2) there was a pile of crud in the carb 3) one of the bolts on the inlet mani had come loose and dropped out, resulting in a bit of 'bubbling' around the manifold on the inlet to #2 cylinder, explaining one reason while she is running a bit crook so 1) put the other coil back in, (Sorry Pete I will not get your coil back to you for a bit) 2) sorted with a clean cloth 3) off to repco/ BNT to get a new bolt, I think there is a spare mani gasket in the shed So tomorrow she will get her timing etc checked out incase the thing had self adjusted herself out of tune. Cheers for your concern. Hope to post a vid of her running like a clock tomorrow Quote Link to comment Share on other sites More sharing options...
felixx Posted July 29, 2011 Author Share Posted July 29, 2011 hmmm factory ballast resistor wrapped around ignition lead. Add this to the ballast resistor I had on the coil that was given to me = 2 ballast resistors 2 ballast resistors + 1 coil = no good 2 plugs are fekked i suspect, (cylinders 2 and 3) new plugs in tomorrw, fek around with timing and HOPEFULLY Happy days! Quote Link to comment Share on other sites More sharing options...
ProZac Posted July 29, 2011 Share Posted July 29, 2011 Do anglias run a really long coil power wire, that acts as a ballast itself? Chevettes do that. Quote Link to comment Share on other sites More sharing options...
felixx Posted July 29, 2011 Author Share Posted July 29, 2011 well mine does, dunno if they all do. it is a long wire curled around the other ignition/ light/ accesory wires. There is no mention of it in the anglia manuals Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted July 29, 2011 Share Posted July 29, 2011 yeah via chevette one is a long single strand isn't it? I remember re-wiring the front loom on my 12a chevette and chasing the coil feed. It went from bulk head up one side of bay then back again to other side in order to get the voltage drop. Quote Link to comment Share on other sites More sharing options...
felixx Posted July 30, 2011 Author Share Posted July 30, 2011 put in 4 new plugs, she fired up nice. 2 ballast resistors do not help! Phil had a tutu with the timing... sexy as can be! Quote Link to comment Share on other sites More sharing options...
anglia4 Posted July 30, 2011 Share Posted July 30, 2011 Sweet! Quote Link to comment Share on other sites More sharing options...
burrowssj Posted August 7, 2011 Share Posted August 7, 2011 im loving the pics you posted on build thread.and that paint choice is mint! although I like that sorta ratrod/old classic condition look to! Quote Link to comment Share on other sites More sharing options...
felixx Posted August 7, 2011 Author Share Posted August 7, 2011 im loving the pics you posted on build thread.and that paint choice is mint! although I like that sorta ratrod/old classic condition look to! Cheers mate, but to be honest she looks like shit... I will be repainting her in the summer. Quote Link to comment Share on other sites More sharing options...
burrowssj Posted August 7, 2011 Share Posted August 7, 2011 have you got $50? http://www.rickwrench.com/index79master ... paint.html Quote Link to comment Share on other sites More sharing options...
felixx Posted August 7, 2011 Author Share Posted August 7, 2011 fark man, thats cool.. I might get some mixed up in anglia blue and try the bonnet Quote Link to comment Share on other sites More sharing options...
burrowssj Posted August 7, 2011 Share Posted August 7, 2011 haha almost seems to good to be true but he uses upto 8 coats an sands each one smooth so could take a while. but no spraying is a bonus Quote Link to comment Share on other sites More sharing options...
anglia4 Posted August 8, 2011 Share Posted August 8, 2011 Fark yeah thats cool! I'll have to look into that for mine too. It seems you can either spend lots of time or lots of money getting it painted. I know in my case I have time but no money haha Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 14, 2011 Share Posted August 14, 2011 Seems more so that they like you. That could have ended a WHOLE lot worse. Quote Link to comment Share on other sites More sharing options...
ProZac Posted August 14, 2011 Share Posted August 14, 2011 Dude, your pretty lucky you didnt lose the whole car/garage/house by the look of it... We can fix it though, will take you up on that offer of a beverage one night Quote Link to comment Share on other sites More sharing options...
governorsam Posted August 14, 2011 Share Posted August 14, 2011 it will look worse than it is. peel the tape/burnt bits off, fix what's left. might have to see if i can make it over one night to give a hand, done lots of this kind of repair in the past. hardest bit is finding grey tape... Quote Link to comment Share on other sites More sharing options...
