Sign in to follow this
Followers 0
felixx
Felixx's Anglia
285 posts in this topic
hay man not to sure if the rear leave bushes are the same as the mk1 escort if so i have some Nolathane bushes only done 6 months.
and i get my escort tie rod ends from ebay normaly landed for about $45.
you can have them .
dan
Share this post
Link to post
this is my mates Anglia..
Admittedly its a race car but still you can get your car close to this low without being retarded and it would be more worthy of praise than when Jesus fed 10,000 people with a fish and a loaf of tip-top..
feel a bit ashamed to have my race car project in the same lockup as his race car so his is so clean mine not so much still however mine has a going engine
Share this post
Link to post
Hi guys thanks for all the feedback. Spoke to Butlers about the tie rod ends $45 each or so, thought that was pretty good.
Cheers for the tips about the bushes. Enford have rubber ones for $5 each or $60 for a set of 8 nolathane ones. I will just get the rubber ones for now I think,Although I will happily trade your nolythane ones for beer Dan
Share this post
Link to post
you would have to make sure they are the same mate .
Share this post
Link to post
liking the build! keep up the good work. I'm also in the process of getting bushes an tie rod ends will let you know how I get on
Share this post
Link to post
I will buy you a beer for offering:)
Share this post
Link to post
Burrowsj >Enford have rubber bushes for $5 each (rubber) or set of 8 nolythane for $60
I rang butlers and he quoted $45 each for tierod ends. I will go in and order a pair on thursday.
Share this post
Link to post
Shit, BNT will be cheaper than that!
Share this post
Link to post
that anglia van is sweet,whats its running??
Share this post
Link to post
I think a 1200 precrossflow. It seemed pretty happy pootling along, but he doesnt push it.
Share this post
Link to post
Like the idea of having a stripe of white down the side. Makes it less harry potterish :)
Share this post
Link to post
awesome.. the garage now has flouro tubes in it. (well 1 batten of 2) 4 more battens to go, but a huge marine SAREX tomorrow so maybe monday (2 weeks off work)
Share this post
Link to post
Love the car but she is definitely an english car..
left the car sitting for 2 weeks, came out to start her yesterday. Flat Battery (the battery IS fucked)
Put Battery on charge.. 4 hours later it started fine.
Backed her out of the garage to begin garage revamp, brake pedal to the floor.. no brakes (master cylinder is full)
Car was warmed up running sweet, went inside to pour a coke, came out car had stopped (within the last 2 minutes, but ofcourse ignition was on)
Restarted car, idling rough, like it has a miss.
Tried to pull each plug lead (one at a time) but no joy finding the missing cylinder
Put it in the garage, pulled each plug, all seemed ok, replaced them, car ran exactly the same.
Went to start her today to get her out of garage... would not start.
As far as the brakes go.. I think i will replace ALL ot the wheel cylinders. I will def do the front shoes and maybe the back ones too. Master Cylinder is new
As far as the engine, when it stalled and ignition left on, have I fucked a) the coil
B) the points
c) the condensor
d) all of the above
*Should this post be in the tech thread?
Cheers, Felixx
Share this post
Link to post
shouldnt be, but I will siphon it out and replace it and see
Share this post
Link to post
leaving ignitino on shouldnt have damaged anything. it will likely be something simple like shit in the fuel lines or something.
Share this post
Link to post
^ Not quite true, but 2 minutes is probably OK and given the car started again it seems even less likely the coil has fried. If you leave the ignition on for an extended period of time and the points are closed the coil will be damaged Beaver.
Felix, I think you need a new battery and then check for spark by watching a plug electrode when the engine is cranking
Share this post
Link to post
ah did not know that sorry, my bad
Share this post
Link to post
Blocked jet/carb/stuck float?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
