kiwitina Posted July 31, 2012 Share Posted July 31, 2012 She will be on widened steels though. autoboner Quote Link to comment Share on other sites More sharing options...
MahaMana Posted September 5, 2012 Share Posted September 5, 2012 Man I'm digging the widened steels bro, nice and subtle. I like the white top and white stripe paint scheme. It is sooooo much easier to use the orig color hahaha dont have to worry about the door frames and all the nooks and grannies! I tell you what I am looking forward to... That drop! haha should be 3 inch drop though Quote Link to comment Share on other sites More sharing options...
1ton Posted December 27, 2012 Share Posted December 27, 2012 Hey just noticed your tacho is same as one Ive had for years now, been in a few of my old cars and currently resides in the Avenger. Does yours read accurately? Mine reads good at lower revs and jumps up quickly with a blip on throttle but the higher the revs get the needle gets more reluctant to move, it seems to slow down so when motor is doing probably about 3500rpm its only reading about 2000-2500. Yes I have had a fiddle with the 4-6-8 switch Quote Link to comment Share on other sites More sharing options...
felixx Posted December 28, 2012 Author Share Posted December 28, 2012 Hi there, mine works sweet, it was only $50 at repco, it sweeps to 5500 rpm, its where the anglia runs out of legs. Quote Link to comment Share on other sites More sharing options...
1ton Posted December 28, 2012 Share Posted December 28, 2012 Mine must be nana/grandad-spec haha, How bout this colour-scheme lol: Quote Link to comment Share on other sites More sharing options...
felixx Posted December 28, 2012 Author Share Posted December 28, 2012 nice bit of rendering, Quote Link to comment Share on other sites More sharing options...
Guest kiwitina Posted March 18, 2013 Share Posted March 18, 2013 Hey Felix. Im looking in to tyres for my widened steelies. They are 7 inch wide. What you reckon? 205 60? 195 60? Would you go wider on yours if you had the chance? Chur Quote Link to comment Share on other sites More sharing options...
felixx Posted June 24, 2013 Author Share Posted June 24, 2013 Anglia failed her wof at xmas.. Since then she has sat up Went to move her last week, grindy noise from rear LH brake.. Brake adjuster stud sheared off/ broke ARRGGH! Quote Link to comment Share on other sites More sharing options...
Llama Posted June 24, 2013 Share Posted June 24, 2013 Quote Link to comment Share on other sites More sharing options...
felixx Posted June 30, 2013 Author Share Posted June 30, 2013 Fixed thanks to big Louie Quote Link to comment Share on other sites More sharing options...
felixx Posted July 27, 2013 Author Share Posted July 27, 2013 Ok so what's the advantage to electronic ignition And if I put a 1500 pre x flow into her could I use the same module Quote Link to comment Share on other sites More sharing options...
BLIZZO Posted July 27, 2013 Share Posted July 27, 2013 Points dont wear out and dont have to set them. In theory shud get a better and more reliable spark. Worth doing if cheap enought. Pre crosflow shud if its same dizzy. Would need to check if coil is compatible I think. Ezcue chingrish on my phone Quote Link to comment Share on other sites More sharing options...
autozoom Posted August 5, 2013 Share Posted August 5, 2013 Ok so what's the advantage to electronic ignition And if I put a 1500 pre x flow into her could I use the same module Hey Felixx, the main advantage of electronic ignition is the "set and forget" aspect. Once it's installed it doesn't need to be gapped or set ever again. Because it's a sensor instead of a mechanical contact, it is more reliable and gives a stronger spark. Even if your car runs fine on points, you will still benefit from better fuel economy with electronic ign. For your Anglia you have different options; you can install a conversion kit into your own distributor for about $80 or you can buy a whole new reproduction distributor for about $200. With both of these options, you don't need to change anything else but we do recommend changing cap, rotor arm and leads to get best advantage from the conversion. Also, I do like to recommend either a Lucas Gold sports coil or a Bosch Blue Coil with the electronic ignition, these are both excellent quality coils without being so powerful they lose their reliability like the cheap 40,000v coils you can get. It all depends how deep your pockets are. There is also a high energy distributor available, this requires a change of coil (to one with primary resistance lower than 1.5 Ohms, such as the ones fitted to cars with factory-fit electronic ignition) these are $250 and the price includes the coil. The new distributors that we supply come with a mechanical advance curve to suit the Anglia Pre-xflow. We are the NZ agents for Powerspark ignition, I'm happy to answer any questions you may have. Cheers, Matt Quote Link to comment Share on other sites More sharing options...
felixx Posted February 12, 2014 Author Share Posted February 12, 2014 Thanks Pete xx Quote Link to comment Share on other sites More sharing options...
felixx Posted June 17, 2014 Author Share Posted June 17, 2014 Well I was gonna WOF her today, but didnt get organised, so WOF tomorrow I hope. Then reg her thurs or fri and then drive her to meat on sunday Quote Link to comment Share on other sites More sharing options...
ajg193 Posted June 18, 2014 Share Posted June 18, 2014 I pay $39 at VTNZ, student price FTW Quote Link to comment Share on other sites More sharing options...
AllTorque Posted June 18, 2014 Share Posted June 18, 2014 Classic rego is so sweet. I usually buy 3 months reg every 5 months. Quote Link to comment Share on other sites More sharing options...
Tele29 Posted June 18, 2014 Share Posted June 18, 2014 Well done great to see it legal! Quote Link to comment Share on other sites More sharing options...
felixx Posted July 31, 2014 Author Share Posted July 31, 2014 hehe was driving along in the snglia last night down lineside road 100kmh and the engine goes from BROOOOOOM to BROOOOOM BROOOOOOM FUCKING BRRRROOOOOOMMM!! Turns out the zorst decided to seperate from the extractors 7 Quote Link to comment Share on other sites More sharing options...
felixx Posted November 15, 2014 Author Share Posted November 15, 2014 So I took the old tart to the shops today, she stalled 3 times, goes great with the throttle on but when you stop at the lights she dies. She also has a whistle at 900 -1500rpm Vacuum leak?? Quote Link to comment Share on other sites More sharing options...
