MACKAZ
MACKAZ's '22 Steel Buick ratrod, "Jailbait"
Had another go. Still no joy. Now petrol is leaking out of the pump diaphragm  and floats are stuck. Checked pump specs and it seems its nominal rating is compatible with the Holley. Ordered a rebuild kit from Proparts. Strip and rebuild when this arrives. I might have a go at dribble feeding it if Old boy visits today. I will get it to work, it isn't going to beat me
Share this post
Link to post
Dribble feed did the job. Had a small fire. Had a lol. Started first pop. It runs good. Time to pull it out and put it in the corner.
  • Like 8
Share this post
Link to post
Thought I'd have a look and see what was out there in the way of a engine mount. The Falcon ones have terrible angles to try and work with. Perusing Trademe and bingoIMG_20200903_163559.thumb.jpg.258e0c1278dda5acc7324179ea34bc63.jpg
GU Nissan Patrol. 4 bolt bottom one stud top. Perfect. A sterling price of $67 for the pair delivered.
Share this post
Link to post
Fired it up again. Fiddle with distributor a little bit. Floats a little high. Fiddle with them a little bit. Sat there idling unassisted for two minutes. 45psi of oil pressure at idle. Couple of good full throttle revs, neighbours poking their heads out. Bloody sterling engine. Old man suitably impressed
  • Like 9
Share this post
Link to post
1st bit of work on this since surgery. Since engine lifter has been repossessed by Dad needed to come up with a solution to get engine and box out again. Made this, its very below average but it workedIMG_20201018_154104.thumb.jpg.e9894a5a7398fb77439b6e6c26818542.jpg
And got it out and gave it a washIMG_20201018_153554.thumb.jpg.9792a5806fc30c064fd4ce5e5989ab81.jpg
Decided to swap out the front spindle assembliesIMG_20201018_153614.thumb.jpg.80a01c38396e1c110c53e63ee3b2bb26.jpg
Yay for vented discsIMG_20201018_154544.thumb.jpg.4e7a985b07ef7a04ab42d73505643edd.jpg
Share this post
Link to post
Cut the remnants of the Holden engine mounts off, and while at it decided to cut the original Mitsubishi ones outIMG_20201018_153640.thumb.jpg.ae4aa322a6625284339e127f35d9fd96.jpg
I will need to reinstate a gusset from spring tower to the chassis. I separated the engine and box and removed the flex plate. I'll source some longer bolts for the flywheel and some for the pressure plate. And it appears Dad may have brokered a swap,  my spare 3 speed for a 5 speed, from what I can gather it's had a cut n shut done on the shifter and cannot be fitted back into a Falcon. 3 speed is in his possession so I'm waiting on him, if not I'll put it back in with one I got
Share this post
Link to post
Had Miss13 as an assistant last night. First was punch in a spigot bearing. Part number 6003-2RS for future reference. IMG_20201020_201238.thumb.jpg.1c0a7f70b3c3dae56c5a2d32b0b9c8be.jpg
Bit of hands on experience in the way of roughing up the flywheel. IMG_20201020_190036.thumb.jpg.2caf21a889a79293d2b81b397b0b3bdb.jpg
Fit flywheel, found 2 bolts don't line up! Quick call to Dad to confirm and he has struck it before. Also confirmed in Fordforums. Mark out the two offending holes and slight finesse with a file. Forgot to photograph this stage. I made a couple of tiny packers and put them in the voids to take up any play that may occur. In speedway circles it is common for guys to bore all 6 holes oversize, but this has a tenancy for the flywheel coming loose. This is a better alternative. Gave Miss13 the job of applying Loctite threadlocker to the M10x1.25x30 12.9 capscrews (quoted for future reference. IMG_20201020_190818.thumb.jpg.9930da1e6a4848cae99091ea4789994e.jpg
Torque to 100nM, spec is 83nM, was recommended by Fordforums member as at 83nM he was finding flywheel coming loose. He used this method, (slightly longer capscrews, Loctite and a little more torque) and has had no further issues
  • Like 8
Share this post
Link to post
Couple of small things done. Tidied the last bits of OEM Mitsi mount off.
Performed a little "finessing" on the Patrol mounts to make them fit. IMG_20201026_124555.thumb.jpg.24fa45b132abfbeb67e1715cd0512470.jpg
Drivers side. IMG_20201026_124525.thumb.jpg.1a4f2b59716cfbe9cddf2587bc5d5d49.jpg
Passengers side.
Share this post
Link to post
