Rookie Posted July 7, 2015 Share Posted July 7, 2015 YUDODIS SPARKLE?!? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted July 7, 2015 Share Posted July 7, 2015 awww yeeee. interested to see how this works out. Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted July 8, 2015 Share Posted July 8, 2015 Hi mate What are you doing for brakes?? On the front end? And rear? Holden calipers? 323? E28? I'm sure you have researched. What are yo planning .I Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 15, 2015 Share Posted August 15, 2015 sparkle really didn't want to do that in the rain but you guys insisted, yeah? Awesome dog guitar. Much lolve. 1 Quote Link to comment Share on other sites More sharing options...
Snoozin Posted August 15, 2015 Author Share Posted August 15, 2015 Lol fucking hell Blizzo. 1 Quote Link to comment Share on other sites More sharing options...
HighLUX Posted August 15, 2015 Share Posted August 15, 2015 Poor Geoff 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted August 15, 2015 Share Posted August 15, 2015 Lush 1 Quote Link to comment Share on other sites More sharing options...
BLIZZO Posted August 16, 2015 Share Posted August 16, 2015 Deeeeeeeeeeezzzzzzzz nutz GOTEMMMM! 2 Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted August 16, 2015 Share Posted August 16, 2015 GREAT PROGRESS GREAT YARNS GREAT TIMES 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted September 19, 2015 Share Posted September 19, 2015 150 dorts at the rubber? Fuu aye, I bet that's fun! Run in and then some wailing on it or 'drive it as you hope to' run in spec? With some typical sparkle nana driving that thing will have glazed bores in no time! 4 Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted September 19, 2015 Share Posted September 19, 2015 190 hp that's impressive. Are you collecting diffs and half shafts already. Still don't know what direction you are taking for brakes. Have you seen the e21build.com brake work with Holden discs and calipers. His motor fit is dodge but the brake work looks legit. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted September 20, 2015 Share Posted September 20, 2015 Dayme son, well done! Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted September 20, 2015 Share Posted September 20, 2015 Did you try to tune out that ruthless rich spot? Will bring the down low power up a lot. May have to play with exhaust lengths to get it. But good effort power wise! 1 Quote Link to comment Share on other sites More sharing options...
sheepers Posted September 20, 2015 Share Posted September 20, 2015 fuck thats a sweet result! congrats you big hipster. 1 Quote Link to comment Share on other sites More sharing options...
BLIZZO Posted September 20, 2015 Share Posted September 20, 2015 Did you try to tune out that ruthless rich spot? Will bring the down low power up a lot. May have to play with exhaust lengths to get it. But good effort power wise! Rodney seemed to think that was somewhat normal and where the cam was coming in. There was a separate graph that showed richness, at first it was really rich down low and lean up high, he changed the air correctors to reduce the richness down low and get rid of the running lean up high. I thought that big dip was abnormal also but i know fuck all about tuning and rodney seems pretty onto it. Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 20, 2015 Share Posted September 20, 2015 Delete any rich spots if the carb can. 2 Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted September 20, 2015 Share Posted September 20, 2015 Efi time? Haha nah just run it. Il try loose that rich spot if it's possible though. It's drowning it! Quote Link to comment Share on other sites More sharing options...
Rookie Posted September 20, 2015 Share Posted September 20, 2015 Good job sprak! You should be well stoked with 150 whp. That afr trace is the reason efi is better than carbs hahaha. But with more tuning you should be able to get it spot on. It looks like it could use different emulsion tubes the way it is climbing up like that. Also that dip looks like its right in the spot where the pilot and main jets change over, but it is hard to tell from the internet. What is idle and low load afrs like? The only thing is that if highway speeds are right in the bottom of the valley you might end up fouling plugs on the motorway, which would be lol and stink all at the same time! Anyway, do a skid ya cunt! 1 Quote Link to comment Share on other sites More sharing options...
Sparkle Posted September 20, 2015 Share Posted September 20, 2015 Cheers lads! Yeah it goes bloody well tbh. Will take on board the above advice and try and relay it horribly inaccurately to the tuner this week. There will likely be a further tune once engine is run in a bit more. Quote Link to comment Share on other sites More sharing options...
CamB Posted September 20, 2015 Share Posted September 20, 2015 Far out that's awesome. Has given me a burst of enthusiasm as my incredibly long winded turbo 2002 project has a similar cam, M3 crank and some lower compression pistons waiting. So if I am lucky I can get that x2 at a sensible level of boost. For reference, I had 102hp at the wheels (dyno dynamics) as a tii. Interestingly, zee clever germans mechanical fuel injection had a dead flat AFR. Quote Link to comment Share on other sites More sharing options...
