-Toyota Chaser MX41- M-EU out, 5M in.
Rusted
Whipped the MEU out, collect the 5M this weekend. I am expecting to only hit a few minor problems but would like to have everything on hand before hand.
Obviously there is going to be a piece of wiring loom that is no longer in use. The ECU should just be unplugged as it has no use anymore, switch over alternators to match my loom.
Is there any impending doom? (Sticking with slushbox as cruiser>drifter)
why not just find an 5M-EU ECU and inlet manifold from a Crown or Cressida? Perhaps the M-EU inlet manifold will bolt to the 5M head and you can run with the existing M-EU ECU with some tweaks to the a/f ratio to compensate.
well when my GT was retrofitted with a carb instead of the original injection, they just disconnected the plug going to the fuel pump, and had the mechanical fuel pump sucking fuel through the EFI filter and pump.
