yoeddynz Posted November 10, 2014 Author Share Posted November 10, 2014 So got home from work (back working on that bedford CF which is now in the paint stage ) and I unbolted all the many little s/s capscrews holding the plenum lid on-6mm thick but it has a bloody twist in it such was the bang! Many welds had popped apart but luckily it looks easy enough for me to weld back together. Once fixed I can look into why it happened. Possibly was a injector leaking? But its only happened twice. Perhaps next time its been sat a while I should hold the throttle down so activating clear flood and clear it back to a fresh start. Hmmmmm pondering. I need to post a msq but not sure how. Quote Link to comment Share on other sites More sharing options...
Testament Posted November 11, 2014 Share Posted November 11, 2014 I saw a picture of a split plenium once. The cause was that when the key was turned on, all four plugs fired once similtaniously. Boom! could it be a leaky injector dumping fuel into the runner? yes megasquirt does do this when first powered up. esp the scenario is its cold and the thing doesnt start immediately so there is a bunch of fuel sitting around. I had this happen when i was diagnosing problems (cranking a bunch with ignition not fuctioning). then i got the ignition to function turned the key and it was like someone fired a cannon out the exhaust. different came timing or just position in the firing cycle at the time could have this effect. 1 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted November 12, 2014 Author Share Posted November 12, 2014 From what Ive read it seems that MS can be configured to hold the timing at a set spot while cranking and you can also have it set to retard (or advance) the timing when cranking? Ive looked for this feature but so far only found a cold advance/retard feature. Its was set at the default whereby for example @ 6 degrees C in temp the ignition is advanced a further 3 degrees. That wont help matters because I have also set my ignition table with a bit more advance in the lowest rpm bins to help stop the engine stalling. Say it idles nicely at around 14 degrees btdc I have the lower bins set at 17 btdc then add on the extra 3 degrees from that cold advance its going to be 20 btdc at cranking- probably a bit too much? I realise all engines are different but Id be interested to know what other peoples cars advance is set at while cranking? I reckon its a combination of things- a leaky injector filling the plenum with fumes maybe combined with too much advance at crank. Certainly has felt like too much advance once or twice when the engine has mildly backfired and felt like the engine is fighting to rotate the right way if yoy know what I mean. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 13, 2014 Share Posted November 13, 2014 I have always worked to set all my tunes at 10-12 degrees static advance which will also be the amount of advance on cranking. 20 initial sounds a fuckload at crank to me considering the piston speed will be pretty slow.. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted November 13, 2014 Author Share Posted November 13, 2014 Yeah I think its too much. Will dail it out. 2.0 litre used to run on about 10 at idle and never backfired. I just advanced it slowly as it idled that bit smoother. Also.. cam overlap....I'm not sure if these 2.5 ZE cams have much more overlap than the 2.0 - whether that would make much difference at crank? I cant imagine there is that many degrees between them. Will do some googling....but not before I finish filing down my oh so not so pretty welds... Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 13, 2014 Share Posted November 13, 2014 What rpm is your first column at? jam another in there at cranking rpm could be an option. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted November 13, 2014 Author Share Posted November 13, 2014 what- move all the columns to the right and loose all that fine definition that I can tune at 8000? But yeah- I could do that, about 300 rpm but i think easier to set that cold advance thing to retard it. From what I can remember its only happened first start of the day when cold. Quote Link to comment Share on other sites More sharing options...
Testament Posted November 13, 2014 Share Posted November 13, 2014 You can use a cranking advance, which it uses up to 300 rpm or something like that I think mine is set to ten. Then it kicks over to the ignition map Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted November 13, 2014 Author Share Posted November 13, 2014 Where do I find the cranking advance? Quote Link to comment Share on other sites More sharing options...
Testament Posted November 13, 2014 Share Posted November 13, 2014 under the ignition tab, open the general?basic? settings tab where you set the trigger offset and dwell etc. in the top right of the window is the cranking settings. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted November 13, 2014 Author Share Posted November 13, 2014 Cool. I'll have a look Quote Link to comment Share on other sites More sharing options...
AllTorque Posted February 1, 2015 Share Posted February 1, 2015 Holy shit balls, that guy! You should be honoured to have him thrash your car. He does some sweet reviews. I'm glad the car performed well on the day. Super keen to so the vid. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post yoeddynz Posted February 1, 2015 Author Popular Post Share Posted February 1, 2015 Hell yeah- definitely a really cool thing! I had not heard of him prior to the PM I had got. After looking the show up I realised it was the guy who did the episode on the zero fucks given rx7 which I had really enjoyed watching so then I was very excited. I had kept it pretty quiet until after the filming was underway because I never knew if the shoot would ever go ahead or if they would actually make it to NZ. Made some good friends - all the crew were top. Hannah got on really well with Sarah who is apparently a very good stunt driver in LA. So we now have several places to stay when next over there It was really intersting watching how the days filming went about, what gear they had and how it was used etc. Matt was amazed at how well the Viva handled for something from the 60's still on pretty stock suspension with nothing but stiffer springs and better dampers. Good modern tyres help though! They loved the mini coke bottle shape and the overall style. Im hoping this vid will raise the awareness of Vauxhalls finest and one day Vivas might be worth hundreds of dollars...... 10 Quote Link to comment Share on other sites More sharing options...
ThePog Posted February 1, 2015 Share Posted February 1, 2015 Stoked it went so well for you Alex, I really enjoyed the RX7 one he did so super duper keen to see this. Quote Link to comment Share on other sites More sharing options...
nzvohc Posted February 1, 2015 Share Posted February 1, 2015 Most excellent! Look forward to seeing the footage and comments from Matt. Credit to your work and ethusiam to all things Viva-ish. Wouldn't it be awesome to cruise LA/Hollywood Hills in your car...a word in his ear perhaps... 1 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted February 1, 2015 Author Share Posted February 1, 2015 Ive told him about the Canadian sold Envoy Epics ... But they are pretty rare now. Quote Link to comment Share on other sites More sharing options...
tortron Posted February 1, 2015 Share Posted February 1, 2015 Dunno if you could increase the number of viva fans already there are literally dozens 3 Quote Link to comment Share on other sites More sharing options...
glen Posted February 2, 2015 Share Posted February 2, 2015 This is awesome, how the hell did they find out about your car ?? Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted February 2, 2015 Author Share Posted February 2, 2015 Found it on oldschool !!!! 3 Quote Link to comment Share on other sites More sharing options...
kyteler Posted February 6, 2015 Share Posted February 6, 2015 Didn't even know about that game. Looks sweet. Consider it bought. Quote Link to comment Share on other sites More sharing options...
