click here for Discussion thread
a new Beasty appears!
those keeping track will count this as #4
via TM ex Borgwieser (2 owners back)
1976 Auto 1600 currently single carb, wof + reg,
yep them 17x7's, my bad, those at Wag gathering will note I will 'torture' myself for others entertainment : to a degree
My new Daily!
Edited by JoKer
Share this post
Link to post
i was baaad
OS forgive me? might have something slightly netter suited by Summit : but not promsing it!
Share this post
Link to post
went Manfield
Played with some Saker's and did drifts
1:49 on road tires, 1:44 on Slicks
Share this post
Link to post
White : back from Panel beaters last week :bounce:
Red : sorted Kick-down cable (earthing issues fused the cable inside itself) last night :compress:
this is the first time they have "seen" each other!
:salute:
Share this post
Link to post
Guest JoKer
My first ever 1500, my 5th Avenger that I have exchanged currency for its possession
was driven up on junk yard bout 5 years ago, RR Brake is locked solid
Share this post
Link to post
BW45 reinstall in progress :D While I'm running around gathering parts Nick is swearing at me for not putting the drive shaft in the boot and misplacing the Dustcover, only missing one bolt so far and since sitting down have found the gear selector linkage on old housing in my workshop
next is a eeek WOF check
Share this post
Link to post
reckon you guys might appreciate the background more than the actual subject
rolled it off this morning, just need to sort starter, ATF and battery and drive it :P
to do list
  • Windscreen rubbers./seal to keep the rain out
  • rear brakes leaking
  • smokey motor
  • oil leaky motor
  • find extra screw to hold airfilter housing on
  • possibly refit TC exhaust
  • wof
  • dort
Share this post
Link to post
Starter in
gas in
2005479525_photobucket_149790_.jpg?t=137
Drove it home :P SO HAPPY RIGHT NOW
to do list grew
  • Service oil/filter etc
  • Axel pack (to sort brake leak
  • Cube of stop leak for radiator, found pinhole
then take back for a soft wof check
Share this post
Link to post
put gas and a battery in it and a sticker on it
the road to NATs 14 begins, few things to do before wof
Share this post
Link to post
neither red nor White car has moved in a while, had my spare set of Nuts turned down to suit the Background wheels
that's about it, Waiting for Funds to accumulate and rust to dissipate before going for Wof on Red
Exhaust still needs re-welding/fixing on White before Dort (I did have a dream I was slaying tires in a paddock the other night in this car, woke up with smile on my face)
Share this post
Link to post
stuff is happening
its in someone elses shed
1653252_10153034208102456_89697226568967
rising front (removing sgged springs
995079_10153034208177456_798917307860214
sort engine mounts
1013622_10153034207927456_66855565523605
Exhuivst
10968547_10153034207782456_3712565545150
10408086_10153034207437456_3433495662873
might be redy for Sundy utoX
10427287_10153034207262456_2274211650777
Share this post
Link to post
pic via Pete : when he did the Daybreaker rally 2005 in it
Edited by JoKer
fixed pic link to Facebook
Share this post
Link to post
extractors cut:re welded & reinstlled
turbo's bolted on & in running order
also found the specs on the cam its currently running
Share this post
Link to post
there's more vids on my channel
not me driving or there'd be more rev's off start (driver getting used to the cam/tune)
tho I did get to go for a hoon at one stage, ahhh tis good
as you can see , needs a tidy up, wish I could haul it up to nat's
Share this post
Link to post
Sign in to follow this
