Wheel offset
Josh
Just looking at some wheels on trademe, he doesn't know the offset and I told him how to get it yet he still has failed. He says they were on a ke26 rwd. Does anyone know the offset of a ke26 then? Need to compare to capri offset to know weather to purchase these or not as pretty keen on em.
Shouldn't have an issue fitting them man, you have positive offset wheels atm don't you? with a 7inch wide wheels you have heaaaps of room to get more negative. I have 15x8s on the back with +15 offset and still have tonnes of room either side of the wheel.
Sweet as, cheers for that, yea I think currents are around +20 from memory. I'm not wanting to run them on the front (although I already run 20mm spacers on front), just using them for drag racing.
Hopefully 110 will fit onto 108, I suppose it's not to hard to get them slotted slightly to fit though.
