be4ver Posted September 30, 2010 Share Posted September 30, 2010 Hey was wondering if anyone could point me in the direction of some info reguarding a rotary conversion on an ex, i know a ton of people have done this before but i cant find biggar all info. Jst want to know whats involved in the mounting process, crossmembers & engine mounts etc. Is it possible to modify the standard crossmember to suit or will a custom one need to be made up? will the driveshaft need to be lengthened or shortened? i have no idea haha ive already done 90% of an n/a 4G63 swap into an ex and now i wanna give the rota thing a go, just want a rough idea of what to expect before i go out and buy an engine n stuff. anything will be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
R100 Posted September 30, 2010 Share Posted September 30, 2010 Depends what engine your fitting. If its just a 12A or non turbo 13b its pretty straight forward. You will need a front sump and pick up. Use standard xmember, grind mounts off. Fit front mount bracket to rotary and fabricate up some mounts to suit. Use a series 1 style RX7 gearbox. From memory youl have to shorten the drive shaft. Its a relitavily straigh forward conversion as far as engine swaps go. Everything depends on your knowledge and access to tools to do the job right. Quote Link to comment Share on other sites More sharing options...
