Testament Posted June 16, 2010 Share Posted June 16, 2010 just out of interest do any of you toyota people know if a lexus v8 will bolt to Aisin A440F/A442F/A450-43LE transmissions used in landcruisers and the like in the early '90s? Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 16, 2010 Share Posted June 16, 2010 What you want to use is a 340H or a340F 4wd box out of a surf etc, they are tough as shit and a 1UZ bell will bolt straight on Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 16, 2010 Share Posted June 16, 2010 Storngest option is probably a mk4 supra box, modified to go onto a 4wd transfer case. Wayne is the expert on this shit Quote Link to comment Share on other sites More sharing options...
Testament Posted June 16, 2010 Author Share Posted June 16, 2010 so I take it then the answer is there is no factory bellhousing that will go A4XX to UZ? Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 16, 2010 Share Posted June 16, 2010 Not that I know of... From above the 2uz is the only UZ series engine to come out factory in a cruiser and it came out in 1998 by then the A44x series of boxes were no longer used. As you can see above it used a A340 Quote Link to comment Share on other sites More sharing options...
Testament Posted June 16, 2010 Author Share Posted June 16, 2010 Yeah I had gathered that already, was thinking more if one of the other engines used infront of an A4XX may have the same bolt pattern as a UZ. Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 16, 2010 Share Posted June 16, 2010 Wouldnt count on it. I did have a google for you found a dude running a 2uz in a a440'd cruiser. He had used an adapter plate so its do-able I'm just unsure if there is a factory option Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 16, 2010 Share Posted June 16, 2010 i think jap spec ambos were standard 1uz 4x4 auto. . . . . is a 2uz like a big bore 1uz? i used a 4x4 landcruiser sump and pan on a old cruiser i put a 1uz into, kicks everything to one side to allow for front driveshaft and diff clearence. Quote Link to comment Share on other sites More sharing options...
Testament Posted June 16, 2010 Author Share Posted June 16, 2010 i think jap spec ambos were standard 1uz 4x4 auto. . . . . is a 2uz like a big bore 1uz? i used a 4x4 landcruiser sump and pan on a old cruiser i put a 1uz into, kicks everything to one side to allow for front driveshaft and diff clearence. 2UZ = more bore and srtoke (4.7L) iron block, different cams, manifolds etc. setup for low down torque in heavy (2500kg+) 4x4s Quote Link to comment Share on other sites More sharing options...
