anglia4 Posted April 20, 2010 Author Share Posted April 20, 2010 yeah i haven't come across any 13x8 hotwires before, 7" is the widest i have seen and they were a reasonable price so i couldn't let them go. just need those darn 16"s to sell now... found a couple of very small rust spots in the front of the car last night, should be easy repairs though. definately on the home stretch for rust repairs now though. That massive hole i cut in the floor is the next challenge though Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 20, 2010 Share Posted April 20, 2010 Good stuff! sweet Wheels! make sure you fit tires to check clearances if you get diff shortening done. Yeah i learnt the hard way cutting out diff and gbox tunnels is the easy bit! Quote Link to comment Share on other sites More sharing options...
Ogre Posted April 20, 2010 Share Posted April 20, 2010 sweet anglia man!!Nice engine build too, go the R1 carbs.Those wheels are gonna look damn mean too Quote Link to comment Share on other sites More sharing options...
EURON8 Posted April 20, 2010 Share Posted April 20, 2010 I at first thought the buldge on the left of car underneath was a tire and was quite excitied by the ride height, bar the fact that the cars on its side. Loving the build though, looking good. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted April 21, 2010 Share Posted April 21, 2010 They arent hotwires, they look to be enkei mesh. sweet build so far Quote Link to comment Share on other sites More sharing options...
anglia4 Posted April 21, 2010 Author Share Posted April 21, 2010 yeah they are made by enkei but basically the same looking wheel. that bulge is a tyre under the car haha but its just what the car is sitting on so the panels don't get damaged while its on edge Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted April 23, 2010 Share Posted April 23, 2010 Hah, I so didnt realise that this was you Jeff. Have to have beers and talk car shit. Dave Quote Link to comment Share on other sites More sharing options...
anglia4 Posted April 24, 2010 Author Share Posted April 24, 2010 haha i figured you were on here somewhere dave but grant didn't know your username Quote Link to comment Share on other sites More sharing options...
anglia4 Posted June 5, 2010 Author Share Posted June 5, 2010 bike carbs or suck through supercharger??? seen pics of runamucks setup and it looks fuckin amazing. would be similar price wise, SC = big hole in the hood, Quads would just look wicked. Can't decide plenty of time to think about it though, since i bought the stang theres not alot of money lying around to spend on the a-box for a while till i get the muzzy all sorted Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 5, 2010 Share Posted June 5, 2010 bike carb'd stroker Quote Link to comment Share on other sites More sharing options...
anglia4 Posted June 5, 2010 Author Share Posted June 5, 2010 bike carb'd stroker i wish!!! Quote Link to comment Share on other sites More sharing options...
Toucan Posted September 6, 2010 Share Posted September 6, 2010 Some nice solid progress there man! Keep it up Quote Link to comment Share on other sites More sharing options...
NaN Posted September 14, 2010 Share Posted September 14, 2010 Got my revised engine mounts welded and fitted up, just have to trim them to make them look pretty and give them a coat of black zinc.They are way better looking than my previous attempt and allow more space for the starter motor. Hey dude; nice progress, but a couple of hard learned lessons about engine mounts. That engine mount design you've done, your putting all your faith into those welds, I'm sure they are good welds, but over time they will be under alot of stress you really should gusset them on all four sides, at each end. Just make up 16 little triangles of 6mm mild steel and weld them in, they will be safe then, and your engine will never come free (imagine if !!!), if it were me I would run supporting lines top and bottom, and then just gussets on the horizontal plane (if you follow me). Solid mounts are fine, they are legal, but they dont absorb the engines vibrations so at some particular rpm the harmonics will shake the car throughout, ok if it's race car, but on the road it wears thin real fast. I think you might be better to use old trailing arm ends and a 6mm mild steel housing to hold them, pretty much a solid mount but ... less likely to introduce harmonics into the shell, and far more likely to absorb the various stresses and vibrations in that location. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted September 14, 2010 Share Posted September 14, 2010 Some good point there nigelwade, wont be hard to do as you got all the hard bits done getting it alligned and fitted. making me think mab i should go solid mount as my rubbers are sarting to split Quote Link to comment Share on other sites More sharing options...
NaN Posted September 14, 2010 Share Posted September 14, 2010 Some good point there nigelwade, wont be hard to do as you got all the hard bits done getting it alligned and fitted. making me think mab i should go solid mount as my rubbers are sarting to split I wouldnt recommend it. The single best engine mount design that I can then off from the point of - cheapest to make - very easy to line up in the car - very very strong - safe - easy to get engine in and out of car, - easy to line up engine in car, would have to be trailing arms gusseted top and bottom length wise with 6mm plate 'fingers' and triangle gussets on the east/west plane, BUT instead of having the opening for the shell end to fit into the crossmember mount facing into the center of the car, have it facing the front of the car, that way the engine can be pulled straight forward off the mounts and out of the car (trust me I wish i'd done that bit myself). Looks something like this, .. but turn the body mount side 90 degress. Quote Link to comment Share on other sites More sharing options...
Mike-e Posted September 14, 2010 Share Posted September 14, 2010 I too am a fan of that design, as even if the rubber in the engine mount bushing should brake the engine still wont go anywhere. Nissan terrano nolathane shackle bushes are a good size to start with Quote Link to comment Share on other sites More sharing options...
anglia4 Posted September 14, 2010 Author Share Posted September 14, 2010 Thanks for the input, the gussets do sound like a good idea, i'll do that next time im home. The welds are strong as, i got a pro to weld them. Although you can't see it in the photos, its not solid mouted, there are capri engine mounts under there. The big rubber dohnut things. If i had been doing it from scratch i would have gone the trailing arm kind of route but the crossmember i have been working from had already been modified to take a capri v6 and had the cross member half of the mounts already made up for me and had the capri rubber mounts too. Just made sense that all i needed to do was finish them off. Quote Link to comment Share on other sites More sharing options...
anglia4 Posted September 14, 2010 Author Share Posted September 14, 2010 you can just barely see them in this pic Quote Link to comment Share on other sites More sharing options...
NaN Posted September 15, 2010 Share Posted September 15, 2010 that kind of engine mount shears away from the steel plate in a crash and over time, if you rolled the car the mounts mount tear away and let the engine roam free. I _really_ dont like that kind I think they're dangerous. Some sort of 'shell' with a bolt through it much safer and more reliable. Quote Link to comment Share on other sites More sharing options...
QCADTA Posted September 15, 2010 Share Posted September 15, 2010 starting to come along nicely, been watchin this build but been to lazy to post. im liking the wheels. good work. Quote Link to comment Share on other sites More sharing options...
