HighLUX Posted November 25, 2014 Share Posted November 25, 2014 Dave will be sweet hes an engineer yaknow Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 25, 2014 Share Posted November 25, 2014 You don't; I didn't give them anything except the crack test when I got my motorbike certed, but suit yourself. Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 25, 2014 Share Posted November 25, 2014 Yeh welder just needs to be good enough to pass the crack test 1 Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted November 25, 2014 Share Posted November 25, 2014 Yeah same with my struts just a competent welder that will pass the crack test. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 25, 2014 Author Share Posted November 25, 2014 I have to either have the weld performed by a trade certified person or the person has to perform a competency test in front of the certifier. It's about a billion times easier to get a trade certified welder to do the welding than it would be to take my welder with me to perform a test run in front of the certifier so that's a no brainer. Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 25, 2014 Share Posted November 25, 2014 Wierd. First I've heard of that. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 25, 2014 Author Share Posted November 25, 2014 Also it needs to be an ultrasonic crack test, not a magnetic cracktest. Maybe it's new standards as of late? Quote Link to comment Share on other sites More sharing options...
beachlander Posted November 25, 2014 Share Posted November 25, 2014 Is that for both Mig and Tig? Or just Tig? Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 25, 2014 Share Posted November 25, 2014 Sounds like your cert guy has been on the pipe. Who are you using? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 25, 2014 Author Share Posted November 25, 2014 I believe it is ALL welded suspension components require tig and an ultrasonic crack test. Can't mig any brake and suspension components, tig only.(this obviously includes the panhard rod which is probably the least threatening of suspension components when it breaks) Quote Link to comment Share on other sites More sharing options...
Beaver Posted November 25, 2014 Share Posted November 25, 2014 Is this direct from Andy or lvvta? Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 25, 2014 Share Posted November 25, 2014 Are you using Andy Smith? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 25, 2014 Author Share Posted November 25, 2014 Manufacture and modification of components 2.3(15) Welding may only be carried out within a brake modification or adaptation if: (a the welding is carried out by a person who: (i) holds a relevant current qualification or trade certification for the type of welding being undertaken; or (ii) has demonstrated to the low volume vehicle certifier, a satisfactory level of competence in the method of welding being undertaken; and (b documentation of a form specified by the Low Volume Vehicle Technical Association Incorporated, which verifies 2.3(15)(a) is supplied by the person who undertakes the welding; and (c welded components which, upon failure could result in a total loss of braking control, are non-destructively tested, using either the ultra-sonic, x-ray, or magnetic particle method, by either a BIP-approved person holding the relevant current certification for the type of NDT being undertaken, or a person holding ASNT NDT Level 3 qualification; and (d documentation of a form specified by the Low Volume Vehicle Technical Association Incorporated, which verifies 2.3(15)© is supplied by the person who undertakes the NDT testing. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 25, 2014 Author Share Posted November 25, 2014 That is from LVVTA - I could be wrong about the magnetic test vs ultrasonic test. Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 25, 2014 Share Posted November 25, 2014 You are, if you follow what it says you can use something that has been mag particle tested that you welded as long as it passes. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 25, 2014 Author Share Posted November 25, 2014 You are combining two things to make your case. Passing a magnetic crack test does not equal passing a weld test. How does a magnetic test check the penetration of welds? An ultrasonic test will - but not magnetic. Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 25, 2014 Share Posted November 25, 2014 Passing a magnetic crack test does not equal passing a weld test. No it doesn't, but I assure you that you can weld it yourself and get cert if it passes a mag particle test. Quote Link to comment Share on other sites More sharing options...
Shakotom Posted November 25, 2014 Share Posted November 25, 2014 Hmm I'm gonna have to go have a nosy under my car at panhard rod now 1 Quote Link to comment Share on other sites More sharing options...
Bistro Posted November 25, 2014 Share Posted November 25, 2014 Manufacture and modification of components 2.3(15) Welding may only be carried out within a brake modification or adaptation if: (a the welding is carried out by a person who: (i) holds a relevant current qualification or trade certification for the type of welding being undertaken; or (ii) has demonstrated to the low volume vehicle certifier, a satisfactory level of competence in the method of welding being undertaken; and (b documentation of a form specified by the Low Volume Vehicle Technical Association Incorporated, which verifies 2.3(15)(a) is supplied by the person who undertakes the welding; and (c welded components which, upon failure could result in a total loss of braking control, are non-destructively tested, using either the ultra-sonic, x-ray, or magnetic particle method, by either a BIP-approved person holding the relevant current certification for the type of NDT being undertaken, or a person holding ASNT NDT Level 3 qualification; and (d documentation of a form specified by the Low Volume Vehicle Technical Association Incorporated, which verifies 2.3(15)© is supplied by the person who undertakes the NDT testing. Is this section only for brake parts? Is there a separate section for suspension modification/weldy weldy? Quote Link to comment Share on other sites More sharing options...
xsspeed Posted November 25, 2014 Share Posted November 25, 2014 that one looks a bit better lol at that fantastic Aussie quality control Quote Link to comment Share on other sites More sharing options...
