KKtrips Posted June 8, 2013 Author Share Posted June 8, 2013 Rockwell crawler axle is the only logical choice TBH.. 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 8, 2013 Author Share Posted June 8, 2013 Like there is any other Rockwell Crawler Axle.. Damns straight I mean one of them.. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted June 8, 2013 Share Posted June 8, 2013 Thats a might big looking air filter you have there and I like it. Could we be seeing some cowl induction in your future? 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 8, 2013 Author Share Posted June 8, 2013 Going to mount an upside down wheel barrow on the bonnet bro. Wheel and all even. 7 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted June 8, 2013 Share Posted June 8, 2013 That's just silly talk. Surely a letterbox will do. 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted June 8, 2013 Share Posted June 8, 2013 Set fire to barrow first?? 1 Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted June 8, 2013 Share Posted June 8, 2013 Get the AXE out and cut a hole! 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 8, 2013 Author Share Posted June 8, 2013 Haha this was discussed and I wondered where I would get 6 milk bottles and a white enameled milk crate to match. Quote Link to comment Share on other sites More sharing options...
yetchh Posted June 8, 2013 Share Posted June 8, 2013 at least if you have a letter box you can put the little red flag up for skids.. 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 8, 2013 Share Posted June 8, 2013 Kk doesn't do skids, just like UJ/machete doesn't text. 1 Quote Link to comment Share on other sites More sharing options...
yetchh Posted June 8, 2013 Share Posted June 8, 2013 wet skids I mean.. 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted June 9, 2013 Share Posted June 9, 2013 The Two Lane Blacktop Chev scoop should be easy. 2 Quote Link to comment Share on other sites More sharing options...
Valiant Posted June 9, 2013 Share Posted June 9, 2013 Hey KK. This is coming along well. I'll just add my 2 cents about the diff. I think you'll grow to dislike the 3.45 pretty fast, personaly I feel a 3.23/1 is the best bet. You can use the gear sets out of Fords and Valiants. XD/E/F utes are a good source of 3.23s and LSDs. Although I have a 3.45 crown wheel and pinion I can pass on to you if you want it. The 2 spider LSDs probably aren't the strongest but the seem to handle some abuse, I haven't broken mine yet, Clint uses one in his turbo Valiant too? Like I said my two cents. *I assume this has a Borgwarner diff* Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 9, 2013 Author Share Posted June 9, 2013 Cheers bro - yeah I pretty sure its the BW I've got to put in. I'll rock the 3.45 to start with and then see how I feel later - consider I have been rocking a 3.9 since I got the car. 1st gear may just be a little blip each time I take off, could always just take off in 2nd I suppose - I do like the sound of an engine labouring away from the lights until the cam comes in.. LOL 1 Quote Link to comment Share on other sites More sharing options...
DodgySam Posted June 9, 2013 Share Posted June 9, 2013 I do like the sound of an engine labouring away from the lights until the turbo spools up.. LOL Quote Link to comment Share on other sites More sharing options...
keltik Posted June 9, 2013 Share Posted June 9, 2013 I do like the sound of an engine labouring away from the lights until the rotors/triangles start spinning at an appropriate speed Quote Link to comment Share on other sites More sharing options...
EURON8 Posted June 9, 2013 Share Posted June 9, 2013 Can you not modify those mounts? Weld them to the car? it already bolts to car and itself so couldn't you weld the car half. Should still be able to remove engine. Quote Link to comment Share on other sites More sharing options...
Valiant Posted June 9, 2013 Share Posted June 9, 2013 Haha sweet. Roadranger dreams. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 9, 2013 Author Share Posted June 9, 2013 Haha sweet. Roadranger dreams. Roadranger or Roadpacer? I prefer the Roadranger 13 speed type dreams myself... By the way Chris the passenger side is fairly solidly bolted in as a plate sits flush against the crossmember - the drivers side has about 8mm clearance which results in it being floppy - I have made a 5mm spacer plate to put into there I hope that will fix it - but I guess the proof will be after the first drive. Quote Link to comment Share on other sites More sharing options...
Valiant Posted June 9, 2013 Share Posted June 9, 2013 Roadranger or Roadpacer? I prefer the Roadranger 13 speed type dreams myself... Raodranger. Definitely roadranger. 1 Quote Link to comment Share on other sites More sharing options...
