Chris's Sidetrack project
Chris.QCR
Changed a few things in the last 6 months. Added a big Sissy bar but then removed it. Big FTW on the inside. Also had a Hand shifter which was also later removed. Ridden it heaps and done lots of wild shit on it. Last time it was ridden was ManCamp14 where we rode 200 k around the peninsula up and down valleys and in and out of bays. Slept in a quarry for the night
  • Replies 42
  • 1 year later...
So alot has changed on this bike.
This is what it looked like at QCR Dirtmasters 2014
Stretched frame with pullack bars
I bent the main frame tube doing too many jumps and it sat in the corner for a good year
Then once id set a date for Dirtmasters 2015 I set about transforming my bike again
So i chopped the bent piece of tubing out and De raked the front forks bring them more upright. Then i welded another smaller diamer tube on the top bracing the neck back to the tank.
Then cut rear guard off and moved top shock mount forward
Fitted a XL175 21" front wheel with a old knobbly and then fitted a new 17" knobbly on the rear for grip
Also fitted a solo seat  and tried two different sets of bars out. with the later Chain curtain window bars being used at Dirtmasters
Also fitted a 110 auto clutch 4 speed Chinese motor for more power donated by hogan.
couldnt find anything i could use for a pipe so welded on a a TMC stainless steel 2 stroke Expansion pipe and it sounded wild!
Overall so happy with the bike that im gonna make it a dedicated dirt bike now. So it will get a new front tire and fork rebuild and then some better rear shocks. pining
