Bombsquad Posted December 17, 2009 Share Posted December 17, 2009 people worry so much about wof without cert, unless youve changed the engine (e.g rotary in piston body) theres a million places that will pass you without asking questions Link to comment Share on other sites More sharing options...
FLAWLES Posted December 19, 2009 Share Posted December 19, 2009 hows it all going shgwag? Link to comment Share on other sites More sharing options...
SHGWAG Posted December 20, 2009 Author Share Posted December 20, 2009 Actually got sweet F.A. done this weekend. Friday got the battery mounted in boot & that's about it due to being drunk from thursday still Saturday pulled out dummy block, mounted coils, sorted fuel & oil fittings & hoses. Still waiting on the fuel rails to come back from engineers. Mocked up new radiator in the mounts we had modified on the original, wont fit with the factory electric fans, so will have to get some aftermarket slim fans. Spent most of saturday afternoon doing NOTHING. Was waiting on the block to be finished. Finally picked up block at 5pm saturday night, went to drop it in & found that there was no spigot bearing in the E-shaft so called it a day. Workshop was shut yesterday so no more progress. Hopefully today I can get hold of a spigot bearing & drop the block in tonight after work. This & the fuel rails are the major holdups. Link to comment Share on other sites More sharing options...
SHGWAG Posted December 21, 2009 Author Share Posted December 21, 2009 Engine = in Tonight all of the manifolds, turbo, throttlebodys, intercooler & piping are going in. Might not have her tuned for new years. But I'll be happy if we can get her started by then.. Link to comment Share on other sites More sharing options...
Bombsquad Posted December 21, 2009 Share Posted December 21, 2009 Dont need tuning for new years man just go ridin dirty I ran out of time and money to finish the cosmos exhaust so 108db @ idle ftw lol Link to comment Share on other sites More sharing options...
SHGWAG Posted December 22, 2009 Author Share Posted December 22, 2009 Loud much?? Want it tuned so it don't lean out under boost & go bang Link to comment Share on other sites More sharing options...
SHGWAG Posted December 22, 2009 Author Share Posted December 22, 2009 Shits getting done, pick up the last of the fuel/oil fittings, rails & hoses today. Won't be online over the xmas break, but if you see a red pulsing batty rolling round H-town, Tauranga/Mt. Maunganui giz a "Hey Boe" Link to comment Share on other sites More sharing options...
FLAWLES Posted December 22, 2009 Share Posted December 22, 2009 you in tga/mt for nw yrs? Link to comment Share on other sites More sharing options...
SHGWAG Posted January 10, 2010 Author Share Posted January 10, 2010 Almost got her done before new year's then stores decided to close / I decided to drink for 2 weeks straight. Worked out how to retain my power steering & aircon, so a little bit of works gone into that. Have had to wait for some places to re-open (Today). Also had to source a second hand loom for plugs (air temp, water temp, crank angle sensors etc.) as my old ones were brittle as. So just a little fab work to be done, however, had to take car out of workshop due to customer's cars having priority, so will keep cracking away at her slowly. Would say possible start up saturday, with it driveable sometime next week. Link to comment Share on other sites More sharing options...
SHGWAG Posted January 13, 2010 Author Share Posted January 13, 2010 Just to prove it ain't pinto powered... Note: Pic was taken before BOV flange was welded on or radiator mounted correctly SPEC LIST: S8 Bridgeport Turbo Block S8 door cards, centre console & dash panels Microtech LT10S Microtech X4 Ignitor 4 x Bosch Coils Masterpower GT37 Turbo Beanie Tial 44mm Wastegate Tial 50mm BOV 3 Core Alloy Radiator New Waterpump Bosch 1680cc Secondary Top Feed Injectors Sard 880cc Primary Top Feed Injectors Sard FPR Bosch .044 (700hp) Fuel pump SX Fuel Filter Battery in Boot Custom Primary Fuel Rail Custom Secondary Fuel Rail Fuel Pump Fittings New Crank angle Sensors MAZDASPEED Thermostat Braided Turbo oil feed / Fuel lines Fragola Fittings 3 Inch Mendral Bent Exhaust 600 x 300 x 76mm intercooler 2x10 inch electric radiator fans Series 7 RS brake rotors & calipers Exceedy Hyper Heavy Duty Clutch Would be running this weekend but I'm away. Next weekend it is. Link to comment Share on other sites More sharing options...
SHGWAG Posted February 19, 2010 Author Share Posted February 19, 2010 Aite, so this things in dry storage at the moment. Moved outa my old flat into a nicer area / house. However, no room at my new place to work on it. Had a wee (massive) hold up on the wiring. However, loom is finished & ready to plug in. (Only the 2 crank angle sensors plugs to sort) Left to do: Dash gauge wiring Bolt on Intake Plug in loom Find a S6 Alternator bracket Bolt on ancillaries Run vacuum lines run water hoses Fill with oil, water, Powersteering Fluid Bleed Brakes, Clutch & Powersteering Check for leaks Maybe start it up... Link to comment Share on other sites More sharing options...
SHGWAG Posted March 17, 2010 Author Share Posted March 17, 2010 So this is out of storage now. Picked up a mint new interior for it tonight, my old one had a few scratches n little broken bits. Stoaked. All of the emissions blank off plates are on with new gaskets. Slowly getting there Link to comment Share on other sites More sharing options...
johnnyfive Posted March 17, 2010 Share Posted March 17, 2010 New Years at the mount? Link to comment Share on other sites More sharing options...
SHGWAG Posted March 17, 2010 Author Share Posted March 17, 2010 Yuh, was there in a FC3S, rather than my FD3s Link to comment Share on other sites More sharing options...
SHGWAG Posted March 20, 2010 Author Share Posted March 20, 2010 Some Photos I took: Cheap shit exhaust manifold: 3 inch mendral bent exhaust: 44mm Tial Wastegate for max thrash action: New Doorcard vs old door card: Some assembly required: Sard FPR with 13b PP KE25 in back ground Tial 50mm BOV The Huffer - Masterpower GT37 This is almost back together with a new dash cluster, old one was all scratched up Love the wide hips on this thing Good Bye Red: Final Result: Link to comment Share on other sites More sharing options...
SHGWAG Posted March 22, 2010 Author Share Posted March 22, 2010 Ok, so I typed up a massive update, hit submit and then it signed me out. CBF'd typing it out again. In summary, shes almost running. Final things are almost done. Rune in tune is booked for Sunday. Link to comment Share on other sites More sharing options...
FLAWLES Posted March 22, 2010 Share Posted March 22, 2010 looking good man the black centers are millons better, must feel good to get to this point in your bulid Link to comment Share on other sites More sharing options...
kyteler Posted March 22, 2010 Share Posted March 22, 2010 Something about the red of the car doesn't sit right, I've probably just seen too many in black or white. Looks weird, also you'll be getting other wheels regardless I assume the blank paint just an interim measure? Link to comment Share on other sites More sharing options...
SHGWAG Posted March 23, 2010 Author Share Posted March 23, 2010 Red is faded from sitting in the sun for 2 years after previous owner blew the clutch. Yes will be getting new wheels when I can afford them. Painting those centres is just a quick jobbie (simple green to clean them, mask & bomb black. Managed to avoid any runs in the paint though. paint will probably wash off of the 1st wet day i drive it. These in white or bronze have caught my fancy: Have also removed front kit and will be slapping on the factory bumper for now. Slight hiccup, cant seem to find anyone who makes alloy mounts for radiator fans, so will have to make some up on the laithe on saturday. Link to comment Share on other sites More sharing options...
Honda Ass Dragger Posted March 23, 2010 Share Posted March 23, 2010 Really liking how this is coming together, the only thing that IMO is Horrible is the "Demon Rotor Sports" window banner Remove that and you car will be Mack 10 Link to comment Share on other sites More sharing options...
