My name is Russell Posted June 29, 2009 Share Posted June 29, 2009 just need to weld a perch for them to sit on Was hoping i could get away with that at least Sweet Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 29, 2009 Share Posted June 29, 2009 Would you trust 3/4 of the weight of your car on eight grub screws? HAHA no not at all! Gaz said you tig them on Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted June 29, 2009 Share Posted June 29, 2009 grub screws are there to stop the tubes moving when you try to crank the spring up a bit there also there as some of the kits come with 'o-ring spacers' for smaller diam struts......do not use just mae the tube wobble and fuck out are the tubes a flush fit with your struts? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 29, 2009 Share Posted June 29, 2009 grub screws are there to stop the tubes moving when you try to crank the spring up a bitthere also there as some of the kits come with 'o-ring spacers' for smaller diam struts......do not use just mae the tube wobble and fuck out are the tubes a flush fit with your struts? Yup very flush will need to hone the alloy out by .5 of a mm so will be a nice fit. So I'm guessing the grub screws will be no use for the above. Makes scenes cheers boe. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted June 29, 2009 Share Posted June 29, 2009 but I think there is a bit more to it that just cranking up the MIG. can if you have a spool of silicone bronze wire but then again hats just fancy soldering or if you have $$$ can get them explosion welded on / buy steal ones Quote Link to comment Share on other sites More sharing options...
Unclejake Posted June 29, 2009 Share Posted June 29, 2009 but I think there is a bit more to it that just cranking up the MIG. can if you have a spool of silicone bronze wire but then again hats just fancy soldering or if you have $$$ can get them explosion welded on / buy steal ones in the correct size for your struts Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted June 29, 2009 Share Posted June 29, 2009 grub screws are there to stop the tubes moving when you try to crank the spring up a bitthere also there as some of the kits come with 'o-ring spacers' for smaller diam struts......do not use just mae the tube wobble and fuck out are the tubes a flush fit with your struts? Yup very flush will need to hone the alloy out by .5 of a mm so will be a nice fit. So I'm guessing the grub screws will be no use for the above. Makes scenes cheers boe. also if you want some more of those lock nuts for added peice of mind (i only saw one on each tube) i have 4 in the garage thread should be the same Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted June 29, 2009 Share Posted June 29, 2009 but I think there is a bit more to it that just cranking up the MIG. can if you have a spool of silicone bronze wire but then again hats just fancy soldering or if you have $$$ can get them explosion welded on / buy steal ones in the correct size for your struts well no point pilfering the wrong ones now is there Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 29, 2009 Share Posted June 29, 2009 grub screws are there to stop the tubes moving when you try to crank the spring up a bitthere also there as some of the kits come with 'o-ring spacers' for smaller diam struts......do not use just mae the tube wobble and fuck out are the tubes a flush fit with your struts? Yup very flush will need to hone the alloy out by .5 of a mm so will be a nice fit. So I'm guessing the grub screws will be no use for the above. Makes scenes cheers boe. also if you want some more of those lock nuts for added peice of mind (i only saw one on each tube) i have 4 in the garage thread should be the same YUP YUP YUP way keen! PM me what ya want for them etc! Was just wondering how the hell i was going to find some. Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 30, 2009 Author Share Posted June 30, 2009 Would you trust 3/4 of the weight of your car on eight grub screws? HAHA no not at all! Gaz said you tig them on Summit Engineering in Rotorua welded my last set up. They are alloy. I thought Johhny would be able to do it in Welly, this is who I was meaning for Chris to get them done by. Jase? Gaz Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted June 30, 2009 Share Posted June 30, 2009 Would you trust 3/4 of the weight of your car on eight grub screws? HAHA no not at all! Gaz said you tig them on Summit Engineering in Rotorua welded my last set up. They are alloy. I thought Johhny would be able to do it in Welly, this is who I was meaning for Chris to get them done by. Jase? Gaz are you sure they were 'welded' as steel to alloy welding is more expensive than micheal jacksons left testicle could they have been press fitted onto a perch? just dont want anybody to attempt this them selves and have there shocks collapse (and then die a horrible painfull firery death) Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 30, 2009 Share Posted June 30, 2009 Jase? Gaz yea????? Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 30, 2009 Author Share Posted June 30, 2009 Yeap def welded, can see the weld. Oops meant other Jase/Unclejake. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 2, 2009 Share Posted July 2, 2009 Gaz: Dunno. We can ask him/I have his number. Treggo: I have not forgotten you but have been too busy to sort out your platforms yet. I will pack them in the weekend Quote Link to comment Share on other sites More sharing options...
treggo Posted July 2, 2009 Share Posted July 2, 2009 Sweet man don't worry too much just whenever Quote Link to comment Share on other sites More sharing options...
Truenotch Posted July 2, 2009 Share Posted July 2, 2009 Perches are the common way of connecting alloy sleeves to steel struts, pretty sure it's cert-able as well. Quote Link to comment Share on other sites More sharing options...
ProZac Posted July 2, 2009 Share Posted July 2, 2009 The weld above the perch, is that from the strut itself being shortened aswell? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 2, 2009 Share Posted July 2, 2009 My guess would be that its the weld from were the old springs seating used to sit? Quote Link to comment Share on other sites More sharing options...
Truenotch Posted July 3, 2009 Share Posted July 3, 2009 ^^ That one is shortened by 40mm for the shocks, and that upper weld will be where they shortened it. http://www.ae86drivingclub.com.au/forum ... hp?p=75969 Oh also, always tig the sleeve or perch onto the housing. Mig ends up cracking. Quote Link to comment Share on other sites More sharing options...
