di0n Posted March 16, 2009 Share Posted March 16, 2009 My Project Thread Let me know what you think... Edit - this used to be called: di0n's 1986 Corolla CE71 Quote Link to comment Share on other sites More sharing options...
Guest Posted March 16, 2009 Share Posted March 16, 2009 high roof is cool Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted March 17, 2009 Share Posted March 17, 2009 Should rock some kind of awesome diesel to keep it diesel just an idea Turbo Diesel that sounds like Seedy al's van Would roool. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted March 17, 2009 Share Posted March 17, 2009 Not overly hard to find a LX81 or something for 2lte awesomeness/poos. 1kzte plz Quote Link to comment Share on other sites More sharing options...
yokonikero Posted March 17, 2009 Share Posted March 17, 2009 hae man. love the hi roof. re the gb, as i found out on my rona if u look where the gb xmember bolts up there should be a series of diff holes. so you can bolt up diff gb's with diff engines and wat not. some one correct me if im rong?? Quote Link to comment Share on other sites More sharing options...
di0n Posted March 17, 2009 Author Share Posted March 17, 2009 Yeh had looked into maybe 3CT or 2LT but both have head problems. 1kzte is an awesome engine too but pricey and wont bolt to my gearbox. 2LT would be cool but I think theyre fairly heavy and look to be quite a high/large engine so not sure if it'd even fit. 1UZFE was my other choice. Did a lot of research but decided it was goin to be too expensive and take too long, after all this is supposed to be my daily... 4age has been done so I know its possible and should be a fairly quick and straight forward swap if I play my cards right and source all the parts before I rip into it. Quote Link to comment Share on other sites More sharing options...
di0n Posted March 20, 2009 Author Share Posted March 20, 2009 Brother has offered to give me his smallport redtop 4age from his AE92. But since im goin to need all the rear wheel drive bits I thought it might be cheaper to just buy a full RWD setup,engine, box and all. And just sell bits I dont need. Or even just run factory rear drive blue top and ditch T50. Thoughts??? Quote Link to comment Share on other sites More sharing options...
AE25 Posted June 15, 2009 Share Posted June 15, 2009 dude you dont need full rwd 4ag stuff. only inlet and exhaust manifs, the water sensor housing on back of head change to bluetop one, and the ae86 spigot bearing. the rest you can use the fwd stuff with an electric fan. for the thermostat run the ae92 remote thermostat under the intake behind the water pump and run a longer radiator hose etc. mod pipe off back of water pump to suit. much cheaper option aye. 3sge would be sweet.. much more involved tho. from the investigations i had fitting w55 into ke70 (same floor pan) the ce71 engine sat in a different spot so the gearbox crossmember was the wrong offset. i ended up using a ta63/ma61 celica gearbox xmember from a W box. had to slot xmember holes 5mm. have been told by another ke70 3tgte owner that the auto xmember bolts on. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted March 4, 2012 Share Posted March 4, 2012 Nice Where did you get those extractors from? Quote Link to comment Share on other sites More sharing options...
di0n Posted March 4, 2012 Author Share Posted March 4, 2012 A guy in Taupo if I remember right. Real stoked with them. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted March 4, 2012 Share Posted March 4, 2012 Ahh i thought i regonised them Quote Link to comment Share on other sites More sharing options...
ryanfels Posted March 4, 2012 Share Posted March 4, 2012 They were made a few years ago for a mates ke70 wagon that he swapped for a 2jz hilux to a guy in taupo Quote Link to comment Share on other sites More sharing options...
di0n Posted March 5, 2012 Author Share Posted March 5, 2012 Haha that will be them. Got a 20v flange on them but that's easy to make fit on he 16v. Quote Link to comment Share on other sites More sharing options...
Dudley Posted September 10 Share Posted September 10 Oi go work on your car 1 4 Quote Link to comment Share on other sites More sharing options...
nobody Posted September 10 Share Posted September 10 14 hours ago, GARDRB said: So I went and got an adapter to screw it into the AN3 front port instead of the AN4 rear port Both those rear ports are outlets only the front port in an inlet Quote Link to comment Share on other sites More sharing options...
GARDRB Posted September 10 Share Posted September 10 20 minutes ago, nobody said: Both those rear ports are outlets only the front port in an inlet Yeah good point, I misread the instructions, it didn't make sense to me that that could be an inlet, must have been their use of "rear" on what I would consider to be the front of the cylinder because it's facing forward. Back to the drawing board. 1 Quote Link to comment Share on other sites More sharing options...
440bbm Posted September 11 Share Posted September 11 just stick a fancy black 90deg male female elbow in it and call it good., at least it will then sit lower LOL Quote Link to comment Share on other sites More sharing options...
GARDRB Posted September 11 Share Posted September 11 21 minutes ago, 440bbm said: just stick a fancy black 90deg male female elbow in it and call it good., at least it will then sit lower LOL 3 Quote Link to comment Share on other sites More sharing options...
440bbm Posted September 11 Share Posted September 11 lols, ok soz haha. remote reso then? 1 Quote Link to comment Share on other sites More sharing options...
Truenotch Posted September 11 Share Posted September 11 Moved the discussion posts here for you @GARDRB 1 Quote Link to comment Share on other sites More sharing options...
