shrike Posted September 10, 2025 Posted September 10, 2025 @kpr overnight parts from Japan? https://toyotagazooracing.com/pressrelease/2025/0910-01/ Quote
kpr Posted September 10, 2025 Posted September 10, 2025 say they bringing back ae86 stuff and have picture of smallport head. amayama have smallport heads listed for 2500. 1 Quote
Rhyscar Posted September 15, 2025 Posted September 15, 2025 Cool progress. Alt bracket is the tits. Staying 3 link on the diff? She's guna be pretty slammed. How much traction are you planning on needing? not much (drifty boy) or lots (drag)? Quote
Popular Post kpr Posted September 15, 2025 Popular Post Posted September 15, 2025 Stock 4 link and panhard setup will stay. It has turreted rear for the s13 coilovers, but not planing on modifying the body anymore. The diff case has been bent for camber, i may take a little out of it. but otherwise just tidying up whats already there with a few tweaks It always put the power down better than the starlet. So will probably struggle to get a wheel going NA. it would have been about 220kw when was turbo. I should probably push it outside and clean the 10 years of filth off it. but i assume it still looks like it did in back in 2011 12 Quote
lush Posted October 19, 2025 Posted October 19, 2025 3 hours ago, kpr said: I could just wind the coilovers up, but thats an illegal move in northland This ^^^^ This is the Bible of Northland 2 1 2 Quote
Dudley Posted November 15, 2025 Posted November 15, 2025 I’m sure old mate won’t have your head too long 1 Quote
xsspeed Posted November 28, 2025 Posted November 28, 2025 Whats the flywheel weight comparison itself like in those ORC combos to others? Reckon the flywheel in the light kit is same as flywheel in the std/ gold cover plate kits? Quote
kpr Posted November 28, 2025 Posted November 28, 2025 Not sure, i assume flywheel is same though. as they also do a full ham one with a super light flywheel. Top one. I'd run it if could get it with the organic plate 1 Quote
xsspeed Posted November 28, 2025 Posted November 28, 2025 whats the orc flywheel you have weigh? they looked 'not that light' when i was looking at pics the other night but maybe cos of the mounts for clutch cover make it look more solid Quote
kpr Posted November 28, 2025 Posted November 28, 2025 dont have anything to weigh it with. but guesstimate mid 4kg. its decent amount lighter than the late ze flywheel have here which is 5.8kg. but wont be as light as the 3.7kg toda one in starlet. for reference the normal 16v flywheels are around the 7kg mark from memory. strangely the late ze one is actually the lightest, then blacktop 20v at 5.9kg nicely made, like most jap stuff 3 1 Quote
RXFORD Posted December 21, 2025 Posted December 21, 2025 Fuel line through the tunnel is a Te Kamo Dave kinda mod. Gonna need like 14 safety loops for that. Quote
Dudley Posted December 21, 2025 Posted December 21, 2025 8 hours ago, RXFORD said: Fuel line through the tunnel is a Te Kamo Dave kinda mod. Gonna need like 14 safety loops for that. So wrong, mr Toyota knew what he was doing, for me I think the whole cert and wof system Is in the wrong once again 2 1 1 Quote
kpr Posted December 22, 2025 Posted December 22, 2025 I'm sure cert man will love it if that ever happens. Is a million factory lines running down the tunnel, along with the one the 15 year ago me ran. I ain't dealing with them at this point. driveshaft is way overkill for the 3hp it will make Quote
Dudley Posted December 26, 2025 Posted December 26, 2025 Welds look shit but otherwise it is a satisfactory update 1 Quote
BiTurbo228 Posted December 28, 2025 Posted December 28, 2025 Huh, had no idea you could mix and match bearing shells. The more you know! Quote
kpr Posted December 28, 2025 Posted December 28, 2025 Yep, they arent round. so with a small change like that, you are only really adjusting the height. Is a lot more side clearance in them. Obviously wouldn't want to try run a 0.25mm oversize with a standard shell. but a 0.025mm is fine. 1 Quote
BiTurbo228 Posted December 28, 2025 Posted December 28, 2025 Ah managed to misread it as 0.25mm rather than 0.025mm! Makes more sense! Quote
xsspeed Posted January 5 Posted January 5 What trans are you running, I'm assuming that's an adapter plate? Does it all play nice with the orc flywheel/clutch you got Quote
kpr Posted January 5 Posted January 5 j160. Its a niteparts adapter plate. works with 4age fly / pressure plate. just need to run a friction plate with the bigger spline Orc setup is an ae86 kit, and i got an altezza friction plate . As the Altezza version of the kit runs the same 200mm plate, just different spine. I made a forward shifter setup for it, probably a page or so back in project thread. 4 1 Quote
