sexingminors hiace
rot808
  • Replies 131
Still got that template for your flares, but since you havent contacted me it is very close to going into the rubbish. Last weekend for you.
I sent you another text today after no reply this weekend.
Maybe its my phone.
Dont worry about it, ill make my own one when i get that far with van.
Thanks anyway
Well after some pissing around with making a new crossmember i discovered the factory one was useable with a little carefull cutting and welding. :rolleyes:
Not to fussed as this way will be stronger and look better for the cert man
will dummy it up tomorrow and see if my measurements and welds were right. then finally welding / coat of matt black.
plus pics
Hey i found some disc's that went onto the stub axels of your hiace they were from a toyota van 86 era.. i then just need'ed a tiny bit of machine down on back of the stub were bearing pushes upto, then a bracket for the caliper off the same vehicle gave it single pots... the wheel bearings were the same aswell!
  • 7 months later...
Also,
Anybody know a place in auckland for acid dipping steel wheels?
Getting them tested left shit all over them, figured it might be easier to dip them and get them back etch primed ready for paint.
Has 8 wheels that would need doing.
one set pretty yuck so way easier to dip them
