1ggze water pump replacement and pully removal?
Mr dori
Im replacing the waterpump off my daily but i cant figure out how to remove old pully, Ive sussed a 2nd hand water pump and that didnt have a pully
heres some pics
New pump minus pully
Old pump
Old pump
the main drive for the pump is the shaft that is sticking out in first pic, i cant see any way that they have attached the pully onto that shaft,
I dunno if you have this manual but here's what I've got.
Looks like you use some form of stud extractor to remove two opposing studs,
LOL!
You put on two nuts and then undo the bottom one, as it presses against the top one it will start undoing the threaded bolt from the pulley. ;)
What?? fuk im confused now, ive tryed a gear puller on it, maybe the wind those studs out so as to stop pully spinning?
More so that the pulley is on evenly and it can push the shaft/pump down and straight off the pulley wheel as opposed to on a slight angle which would cause a binding issue.
LOL!
Yeah i know, some form covers more than one.
I have a speshul tool made for removing studs ands its awesome.
