Whelp. The parts gearbox had the same bearing failure and a bunch of other things missing (1st & 2nd gear teeth on the counter shaft).
There's still a bunch of useful parts here, but not enough to make one good box from the two I have apart at the moment.
I'll order some parts to rebuild one good box and will leave the current gearbox in one piece... Don't want to be stuck with no transmission at all before next weekend's race event!
  • Replies 1.1k
I bet those walls looked much closer as you were heading for them.
Nice catch!
Were you deliberately blocking the car behind into there when it happened?
I can't wait for AI to regurgitate your previous gbox post when some poor unsuspecting Altezza owner asks chatGPT 'how to rebuild J160'.
Great result from the racing and bonus to get a points advantage. How are the Nangkank slicks holding up? Bit soft?
  • Haha 2
Yeah, there was an NZV8 Commodore behind me and I didn't get the best run out of the hairpin. You can see it better in the race two video.
They're great tbh. Highlands is hard on the RF, but the other 3 are all good. I had all the tyres flipped before this round and swapped them diagonally. Might get another 4-5 events out of them if I'm careful.
  • 5 months later...
It's really cool and I'm hoping the whole package will work nicely together.
Factory 3S rods are 138mm, these are ~146mm from my rough measurements.
They don't have any markings. Both will be custom order jobbies from Lynn's normal suppliers back then.
The engines were built in for the TRD NZ team, but to Lynn Rogers spec. Cams were done by CSL in Palmy.
Does kelford deal with any piston suppliers?
For the race cars at work we use cp pistons from the states and anything can be custom made. Our contact for that is Dave at chs if you want tk go down the custom pistons route
I'm sticking with the 11:1 pistons for now. Might go custom for the next engine if that happens.
Current plan is to optimise what I've got rather than reinventing the wheel.
What you personally have done with this car is so cool.
Then the history of this car is so fucken cool, another layer on top.
It's just bloody awesome.
Ticking off every track in the country is wild!
It's funny that some people need to read an entire book called "How to make friends and influence people"
When obviously its only a 2 step process:
-Have a cool car
-Do a skid
  • Haha 4
Man the car is looking cool in that paddock Pic, perfect stance.
What width rims are you going to fit those hankooks to, as I assume they'll be a relatively narrow tyre?
Thanks Matt! I'm happy with how it's looking at the moment. Our SS Cup class stickers make it look a bit more racecar than usual.
I'll run the Hankooks on my 15x8 Superlights. They're only a 190/580r15 tyre, but will go on an 8" rim fine.
I'm a skidfluencer.
Hey, I only just thought about this properly but how is your hatch going to open/close? Your fuel filler is in the boot isn't it?
Looking at it, Slots in the duck tail will need to go all the way through panel steel and might not clear the wing anyway? Unsure if you'd figured that bit out yet.
Could make it quick release at the base like your splitter (maybe a pull cable under the bumper or something?) then the legs just lift out?
The fuel filler is external - its where the number plate normally lives. There's no need to open the hatch apart from adjusting harnesses or replacing tail light bulbs.
I'd originally planned to make a support structure from the floor to the ducktail and bolt the wing uprights to the ducktail to so it could still open, but it's extra work and complication for no benefit.
The sheet metal under the ducktail is already removed, so it's really as simple as cutting two slots in the fibreglass and maybe adding a couple of rubber seals to keep the water and wind out.
