Truenotch Posted May 18, 2025 Author Posted May 18, 2025 I'm just going to run with a "if it looks installed, it is installed" rule for everything from now on. If the bonnet goes down, the pins go in, no matter if it's sitting in the garage or at the racetrack. Haha, I had the same thought about backing plate swarf possibly killing the engine and was pretty careful while I made the plate to make sure that didn't happen. The sparkly fibreglass dust that filled my engine bay while dragging my bumper around Highlands is the real motivation for installing this. 4 1 Quote
Roman Posted May 18, 2025 Posted May 18, 2025 Thats a good way to approach it! So easy to get distracted by something else going on, and forget you havent finished doing something. 2 Quote
shrike Posted May 19, 2025 Posted May 19, 2025 2 hours ago, Truenotch said: I'm just going to run with a "if it looks installed, it is installed" rule for everything from now on. If the bonnet goes down, the pins go in, no matter if it's sitting in the garage or at the racetrack. Haha, I had the same thought about backing plate swarf possibly killing the engine and was pretty careful while I made the plate to make sure that didn't happen. The sparkly fibreglass dust that filled my engine bay while dragging my bumper around Highlands is the real motivation for installing this. 1 hour ago, Roman said: Thats a good way to approach it! So easy to get distracted by something else going on, and forget you havent finished doing something. Prestart/race checklists are also a good option OR RED flags that have the be removed for the bonnet to be locked? Got to walk around with the big racechecklist clip board and tick everything off Oil in engine. Check Tyres inflated. Check Fuel. Check Bonnet locked, Check etc :p Quote
mjrstar Posted May 19, 2025 Posted May 19, 2025 I have an under bonnet battery isolator, if the isolator is on then the latches get clipped when the bonnet is closed. Unlatched in the garage is all good and means I can tell the battery is off. So pretty similar to your plan @Truenotch 2 Quote
Truenotch Posted May 19, 2025 Author Posted May 19, 2025 53 minutes ago, shrike said: Got to walk around with the big racechecklist clip board and tick everything off Oil in engine. Check Tyres inflated. Check Fuel. Check Bonnet locked, Check Sounds great, if you have a crew. My race days mostly consist of me being there on my own, talking to far too many people in the pits, followed by realising my car needs fuel before the next race and frantically throwing 10L into it and whipping my helmet on to head out. Check lists will not be used with enough discipline to make them useful (maybe they'll be used if I decide to do a full season of racing rather than just fun club days). 1 1 2 Quote
GARDRB Posted May 19, 2025 Posted May 19, 2025 Surely you've got bonnet electromagnets running off your PDM and your dash flashes up "Check bonnet electromagnets you ADHD fuck" when your wheelspeed sensors show over 3km/h and positive oil pressure 2 Quote
Truenotch Posted May 19, 2025 Author Posted May 19, 2025 16 minutes ago, GARDRB said: Surely you've got bonnet electromagnets running off your PDM and your dash flashes up "Check bonnet electromagnets you ADHD fuck" when your wheelspeed sensors show over 3km/h and positive oil pressure ............ Ahem...... On 18/05/2025 at 21:26, Truenotch said: *the bonnet repairs are from a separate incident that happened at that last race meeting that I'd prefer not to talk about... But you might be onto something. Install a spring that holds the bonnet up like a factory bonnet catch and have a little car alarm switch going to MoTeC C127 dash that solely exists to give me a "BONNET PINS" alert. 2 Quote
GARDRB Posted May 19, 2025 Posted May 19, 2025 3 minutes ago, Truenotch said: ............ Ahem...... But you might be onto something. Install a spring that holds the bonnet up like a factory bonnet catch and have a little car alarm switch going to MoTeC C127 dash that solely exists to give me a "BONNET PINS" alert. @Stu suggested I run an early link just to turn my fuel pump on and off, he'll be all over this. 2 Quote
Roman Posted May 19, 2025 Posted May 19, 2025 Are there any more events coming up soon @Truenotch ? Quote
Truenotch Posted May 19, 2025 Author Posted May 19, 2025 Not for a while. I'm planning to do some upgrades and repairs over winter and be ready for a good spring/summer/autumn of motorsport next season. 1 Quote
Roman Posted May 20, 2025 Posted May 20, 2025 Cool, do they let you use the dyno at work for beams related activities? Quote
Truenotch Posted May 20, 2025 Author Posted May 20, 2025 Absolutely. Andre is keen to give it a fettle and I really want to learn how to tune the car myself. I have a set of Jenvey throttles to test and see if the blacktop throttles are restrictive... And two engines to put together for other tests before the end of winter.... And a loom to build. 5 1 Quote
Popular Post Truenotch Posted May 20, 2025 Author Popular Post Posted May 20, 2025 @Roman here's the Jenvey setup ready to test. It uses the intermediate plate and isolator section from the factory manifold with an SLS or MJF printed carbon/nylon manifold to the Jenveys: Connor printed a stainless 4-1 collector and it's so sweet: 11 1 Quote
Vintage Grumble Posted May 20, 2025 Posted May 20, 2025 Them TE37 reps got the old ladies flaps clattering eh Fucking love this car BTW, and so jelly of your current situation, you son of a gun you. 1 Quote
mjrstar Posted May 20, 2025 Posted May 20, 2025 Pictures are epic! I reckon the best thing about tarmac hillclimbs is it can be a real leveler for car performance / budget. For instance a relatively low hp basic na 2wd car can teach the big boys with thier bigger budget (thinking turbo awds) a thing or two. Which doesn't really happen in either circuit racing or gravel rally. For instance at my last event in the top 10 cars overall: 3× Honda b series 1st 4th 7th targa wrx (2nd) evo 10 targa car (3rd) Sanderson starlet (dual driven 5th and 6th) 8th evo 9th bmw targa 10th honda powered escort. Followed by a mix of evos other turbo 4wds and a bit of everything else. 2 1 Quote
Truenotch Posted May 20, 2025 Author Posted May 20, 2025 2 hours ago, Vintage Grumble said: Them TE37 reps got the old ladies flaps clattering eh "Old lady flap clatter" is the true meaning of Vintage Grumble. 42 minutes ago, mjrstar said: I reckon the best thing about tarmac hillclimbs is it can be a real leveler for car performance / budget. Yeah, for sure. Coronet Peak is quite steep and has some tight hairpins, so it's one of the few that really favours high horsepower 4wd cars. They can point and shoot through a lot of corners and don't need to deal with carrying momentum in technical sections like other hillclimbs. The smaller cars still punch above their weight though. Here's the results from November. I was 15th out of 37 cars and there's only one 2L car ahead of me (he and I were meant to be class B, but there was an admin mishap). 1 Quote
mjrstar Posted May 21, 2025 Posted May 21, 2025 Nice result, I recognise a few of the names as early evo owners, and maybe a couple of honda drivers doing alright. 1 Quote
GARDRB Posted May 21, 2025 Posted May 21, 2025 @Roman, @Snoozin should we go to Queenstown in November? Quote
