One more post for this page, so I'll make it about something boring. (edit - oh nooo, I've miscalculated! TOTP fail 😅).
At the last round of racing, I noticed a bit of a wave pattern on the outside edge of my Nankang slicks. This kind of "cupping" or "scalloping" is normally caused by overworking the tyre in some way, and can be exaggerated by worn shocks or suspension bushings.
The RF tyre takes the most load at a couple of points of Highlands A&C track - particularly the Carousel, which is a high cambered corner and I reached a sustained 1.3-1.5g through it. The last round was hot and I'd been experiencing some understeer through there, so it's possible that this graining and wear should be expected. I'll flip the tyres around before Round 3 to try and use the other side of the tyre, haha.
You can see here that the inside edge (right) still has tread depth dots. The outside dots have disappeared all the way around this tyre. The other 3 are fine.
The Nankang carcass is a lot softer than the Kumhos, which will also be a factor here. They seem more sensitive to setup and pressure changes - something to keep an eye on!
I still have a set of Kumhos that are less than half worn, so will get through the season OK if the Nankangs run out of rubber.
  • Like 9
  • Replies 254
  • Truenotch
    254
  • 5 weeks later...
  • 3 months later...
