10Speed's '68 VW Bug
10Speed
  • Replies 66
all fitted in, with an additional oil cooler and fan, no cuts to the body...
however a test run with out boost at this point has revealed a leak between head and cylinder... fixing this means removing the engine and getting the head fly cut... which means the new engine won't be debuting at Meremere next weekend )-;
so in a little more detail...
currently has screamer pipe, might be legal this far back?
also has muffler, but I also have a dump pipe to replace this with when going to the track
has fuel pressure reg and guage in the crappiest place ever - but kind of works
has a wide drop sump, total oil capacity is about 6l now, also provides a handy return point for post turbo oil
also has a proper oil filter, first time I have had one of these on a vw
it also has one of these bolted underneath...
  • Like 9
Well that was short lived...
driving a long the motorway making blow off value noises....  waiting at the lights at the off ramp with the clutch in... release the clutch and it seems gearbox has locked up... manage to push it to a traffic island (with the help of an Impala driver).... sigh....
off to google the symptoms now...
still having transmission issues (cheers for the escort home from burgers Chris and Tara), new trans is on the way - will hopefully be here in time for OS trackday...
in the meantime I have been talking to an old school formula vee racer/builder guy about how they made their cars handle, as they use the same front suspension that I have.  And he has kindly sent me a set of camber bushes and hand written instructions on how to fit them :-)
These will take the front end from positive camber into negative camber...
  • 3 months later...
unsure how much sense this pic will make to most... but the brackets to hold the IRS are in, as well as the irs arms, as well as the irs gear box, as well as a chassis brace (axels are still to be added)
this pic is a bit more self evident..
some research I should have done ages ago...
rear track early swing axle 1288mm
rear track late swing axle  1300mm
rear track irs              1349mm
the new drums also add 2mm to the track, but bottom line is the rear track is 63mm greater than it used to be...
beetle rear control arm
I have heard rumors that clever men have been able to narrow these 25/29mm between the bearing carrier and the spring plate mount so that might be a possibility in the future..
