Tortrons series mm minor of slow
tortron
  • Replies 139
  • tortron
    140
bit more work today
installed a tiny amp to run from my mp3 player (yuh wires have since been tided - even used grommets and everything
and started making up a blanking panel to hide the compartment where the sparewheel etc is
will carpet it or soemthing along with the boot
cho
spent ages on bonnet getting is nice
re welded on the bonnet support as it has polled through the spotweld and bent a little
took out the bend
sanded out all the gouges - can only assume someone tried sanding it with a pair of keys?
tonnes of stone chips on the drivers side of the hump
theres about a teaspoon of bog in the whole thing
should be fairly smick now
Yo dawg
We heard you like morris minors
so we put a morris minor in yo morris minor
so you can hold up traffic while you hold up traffic!
il go back for the rest of the running gear and panels/doors early next week
theres about 3 cars worth of parts!(including one they are choptopping)
chur
skids on brew
next step is to remember where i put my other spare carbs
figure out how to mount to engine (bolts are horizontal rather than that angle stz) some sort of adaptor flange or something?
figure out/build linkages
decide what airfilters i want to run (2 original ones, adaptor to a single original, twin pancakes/cones etc)
cut up my spare combined intake/exhaust manifold to suit/make extractors
  • 4 weeks later...
probably good for doubling the bhp
but seriously
this is close to what im planning on having
all i need now is the choke linkages to arrive and a fuel line splitter - then dort dort
(note*
also need an exhaust to run with these - may cut down a standard manifold for now- have some bike headders im going to have a play with)
yikes, bottom of 2nd page bump
carbs and all linkages are done - all shiny and functional
just need to make the manifolds up, so giz your profile cutter or something :wink:
since just before the beach hop i have been having a prick of a time with the car randomly developing (usually after a bit of high revs, but not all the time) a miss, which would sometimes go away if i could get the revs up enough.
so gave the inners of the distributor a good clean (springs and plates were gummed up with something (no vac advance on this))
gave it an oil
replaced rotor - the one in there had a loose (2mm movement either way) contact
recrimped grounding wire as it was nearly broken through
and hello, problem is solved :D
a combination of all of the above was leading to the timing becoming all over the show at random times.
runs nice and smooth and starts 1st pop once again, so thats pretty meke. Timing wants to be a little more advanced than it is now but thats no problem. As an interesting point, the owners manual states that you should advance the timing until it starts to pink and then back off "a bit" playing it by ear until optimum performance is obtained :lol:
Have my spare engine stripped down to its component pieces, all of which are undergoing cleaning and eventually respray of the block and other little bits, polishing of all the alloy (not sanding as i want to retain the cast look, tho i am removing the worst of the casting marks).
before it all goes back together i will see what can be improved in the porting side of things
reground cam
double valve springs
lightened fly wheel
to go with my twin carbs and headers
she should fly along quite nicely
at the moment bodywise she is undergoing some major prep work
currently have half the outside primed and block sanded, removing any nick or scratch that threatens to mar the new paint job.
Not too much to do really, theres only 1 dent on the thing and that was pretty shallow anyway.
Dont remember if i mentioned, but i stripped down the front wings and removed teh shitty bog job hiding the rust in the rear of them (every morrie rusts here) giving the mig a good work out. The only other rust is in the boot lid - which is slightly worse than i thought, but shouldnt take more than 5 mins to patch.
next to do is finish the exterior sanding
interior sanding
prep inside boot (removing gas tank as i want to paint this differently)
prep engine bay (will remove as much as i can, not that theres anything really to remove :lol: and pop out the engine)
then a final strip down of anything i dont want paint on, then spray everything (will be a front and rear wing off paintjob for lushness)
have changed direction a little from what i was originally intending, but i think its going to come out real nice
but il keep that under my bowler hat for now :lol:
just as a wee milestone
shes now rust and hole free!
tho thats not all that impressive as there was barely any rust in it
edit:
also exterior is now just about ready for its final paint 8)
need to do interior, in boot and under bonnet also
  • 4 weeks later...
