Guest vvega Posted February 16, 2008 Share Posted February 16, 2008 yea, you will find that they and beetles, and probably imps tend to spin around while going around corners I could hold a slide in my 54 just fine, and it didnt even have lsd! mr2's are dangerous. its all in the setup. typically heavy rear = hard to slide, once slides, cant be got back typically light rear = easy to slide, once slides requires great skill to get back 50/50 = dream to drive and even tyre temperature when pushing hard. bike engine based engines FTW! if i can lap a roundabout 3 times holding a slide in a mr2 id put it more down to driver skill than bad setup...but in saying that..most aw11's ive driven are setup poorly driven a few 911's only had spins when i backed off gas.....thats pritty much teh issue i think people tend to drop balls lift off and make a mess of it and there underwear Quote Link to comment Share on other sites More sharing options...
pies Posted February 16, 2008 Share Posted February 16, 2008 yea, you will find that they and beetles, and probably imps tend to spin around while going around corners I could hold a slide in my 54 just fine, and it didnt even have lsd! mr2's are dangerous. its all in the setup. typically heavy rear = hard to slide, once slides, cant be got back typically light rear = easy to slide, once slides requires great skill to get back 50/50 = dream to drive and even tyre temperature when pushing hard. bike engine based engines FTW! if i can lap a roundabout 3 times holding a slide in a mr2 id put it more down to driver skill than bad setup...but in saying that..most aw11's ive driven are setup poorly driven a few 911's only had spins when i backed off gas.....thats pritty much teh issue i think people tend to drop balls lift off and make a mess of it and there underwear all up i've been driving MR2's for 3 years. both SW20 and AW11. If your not a dumb retard slackjaw inbred pile of shit d1 tryhard homo wannabe, then MR2's are pretty good once in an intentional slide. predictable to a certain point. once you hit that point though its all over christ.... need more tequila Quote Link to comment Share on other sites More sharing options...
twosmoke Posted February 16, 2008 Share Posted February 16, 2008 . Quote Link to comment Share on other sites More sharing options...
peteretep Posted February 16, 2008 Share Posted February 16, 2008 have you seen a motorbike engine before? Left side is the engine and the right side is the gearbox Quote Link to comment Share on other sites More sharing options...
tortron Posted February 16, 2008 Share Posted February 16, 2008 yea gearbox is down in the sump Quote Link to comment Share on other sites More sharing options...
lowgan Posted February 16, 2008 Share Posted February 16, 2008 the bike engines box will be far easier to do the conversion i think. open wheelers and the likes use starter motors the engage onto teeth on the rear discs. that would be cheapest easiest option in my mind. but if u slapped say a gsxr1000 turb engine into a datsun1200 ute im sure u could open the door and flintstones it backwards piece of piss. Quote Link to comment Share on other sites More sharing options...
84_S12 Posted February 16, 2008 Share Posted February 16, 2008 If your motorbike is not RWD, you're facing the wrong way But seriously now, why not just buy a motorbike?? Quote Link to comment Share on other sites More sharing options...
insanebrain Posted February 17, 2008 Share Posted February 17, 2008 Why does nobody use a conventional gearbox behind one of these things? Its always the stocker gearbox, and then various workarounds to get reverse. I know it is possible for some motors - for instance the Fiat FIRE 1000 (from Uno) and 1100 (from Punto's) were designed in conjunction with Kawasaki and are used in some bikes. Another issue n one has mentioned yet is bike engine sumps. Bikes don't incurr much lateral g because (a) they lean over and ( they don't have the tire area thus grip of a car (hence the different racing lines of bikes vs cars). As a result most bike engines require modifications to their oiling system when put into cars.[/code] Quote Link to comment Share on other sites More sharing options...
Guest vvega Posted February 17, 2008 Share Posted February 17, 2008 Why does nobody use a conventional gearbox behind one of these things? Its always the stocker gearbox, and then various workarounds to get reverse. I know it is possible for some motors - for instance the Fiat FIRE 1000 (from Uno) and 1100 (from Punto's) were designed in conjunction with Kawasaki and are used in some bikes. Another issue n one has mentioned yet is bike engine sumps. Bikes don't incurr much lateral g because (a) they lean over and ( they don't have the tire area thus grip of a car (hence the different racing lines of bikes vs cars). As a result most bike engines require modifications to their oiling system when put into cars.[/code] most teh bikes that i have pulled down have some of the most impresively baffled sumps ive ever seen Quote Link to comment Share on other sites More sharing options...
peteretep Posted February 17, 2008 Share Posted February 17, 2008 weve wasted up several motorcycle engines doing donuts and starving of oil Quote Link to comment Share on other sites More sharing options...
tortron Posted February 17, 2008 Share Posted February 17, 2008 yea its generally the front cylinder that gets starved, wonder why Quote Link to comment Share on other sites More sharing options...
Jay GTi Posted February 17, 2008 Share Posted February 17, 2008 Why does nobody use a conventional gearbox behind one of these things? Its always the stocker gearbox, and then various workarounds to get reverse. I know it is possible for some motors - for instance the Fiat FIRE 1000 (from Uno) and 1100 (from Punto's) were designed in conjunction with Kawasaki and are used in some bikes. Another issue n one has mentioned yet is bike engine sumps. Bikes don't incurr much lateral g because (a) they lean over and ( they don't have the tire area thus grip of a car (hence the different racing lines of bikes vs cars). As a result most bike engines require modifications to their oiling system when put into cars.[/code] most teh bikes that i have pulled down have some of the most impresively baffled sumps ive ever seen Perhaps, but almost all bike engines that end up in kit cars that then up as trackday toys need dry sumping. Most are fine on the road however. Quote Link to comment Share on other sites More sharing options...
Guest vvega Posted February 17, 2008 Share Posted February 17, 2008 wierd some of the speed way boys pull some good g's and have no issue i guess it sounds liek something you would do out of a matter or course ///adds another 1500-2 grand+ to the cost of the build + you have to work out how to drive it on toop of that on all the utube vids iv seen and all piccys ive seen on these projects ive never seen a drysump on one wonder if the fase team has one on there uni project would almost make it cheaper to build a worked car engine Quote Link to comment Share on other sites More sharing options...
lowgan Posted February 26, 2008 Share Posted February 26, 2008 http://nz.youtube.com/watch?v=mnfxG42lO ... re=related watching that makes me want to no matter what Quote Link to comment Share on other sites More sharing options...
fishtailfred Posted March 14, 2008 Share Posted March 14, 2008 MR2's are pretty good once in an intentional slide. predictable to a certain point. once you hit that point though its all over That's the point. You can slide them on purpose just fine. Piss easy. No worries. Ditto ANY car. However, when you are going REALLY fast (the true meaning of that seems lost on a lot of people) and pushing the limits NOT trying to slide, that is when they become dangerous and unmanageable. Beetles typically aren't capable of going fast enough to have issues Not a fan of the later mr2. I'd have an early 11 series one despite any faults it does or doesnt have though. When you push a nicely balanced car too hard with it neutrally balanced, it will be pretty benign. You can force a nicely balanced car into a state of imbalance and it will spin just the same. Even the best driver can't take a std mr2 or audi TT or or or or past the limit and get it back. Thats the point Quote Link to comment Share on other sites More sharing options...
sentra Posted March 14, 2008 Share Posted March 14, 2008 Why does nobody use a conventional gearbox behind one of these things? Its always the stocker gearbox, and then various workarounds to get reverse.Just a thought. just a point on this, working under a guy that builds bike engines for dirt track, he chops the gearbox off on bandsaw, cleans the remaining surface off in the mill, plates it up, pretty much done/ultra simple. team that up with an adaptor plate and a suitable gearbag and youd be in business (i bet youd sell alot of adaptor plates too) 1 Quote Link to comment Share on other sites More sharing options...
Guest sexychevette Posted March 14, 2008 Share Posted March 14, 2008 Also, it says he doesnt use a clutch for shifting one he is running, is this normal, flat shifting bikes? Im not aware of any bikes that are designed to be shifted without a clutch. However theyre pretty forgiving, if you just bang it through even without rev matching it will go with no noise(just not quite as smooth) If I owned the gearbox Id use a clutch though. u stupid. bikes have dogboxes=clutch just slows you down on the upshift if you're fanging it. Also it will change more smothly without the clutch on the upshift if you change at the right time etc. fuck i cant be botherd reading this thread. Just go get money and put that shit into carryvan Quote Link to comment Share on other sites More sharing options...
Guest sexychevette Posted March 14, 2008 Share Posted March 14, 2008 weve wasted up several motorcycle engines doing donuts and starving of oil should of gone twostroke fool Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted March 14, 2008 Author Share Posted March 14, 2008 If your motorbike is not RWD, you're facing the wrong wayBut seriously now, why not just buy a motorbike?? I(f I wanted a motor bike I would just buy one. My only consern for the going backward part with a starter motor is torque for hills etc Allan Quote Link to comment Share on other sites More sharing options...
