Brock-Lee Posted April 22, 2011 Author Share Posted April 22, 2011 started cutting the rear of the ute today. That bracket was for the OG massive as balls bumpstop. This was hitting the diff heaps as so I cut it off Oh Hello big hole in chassis rail Will cut a notch into rail after I get springs made up and shit. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted January 2, 2012 Author Share Posted January 2, 2012 /so this is a boring as fuck update. So I cut the massive spring mount towers off the chassis today and then just welded the pivot tube to the chassis rail and proceeded to build a box around it to make it all strong like. That thing^... Became that^... Which became that^ And I dont have the photos of the next bit. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted January 7, 2012 Author Share Posted January 7, 2012 Welded it up today. Took a blurry photo so my welding looks better etc. Now with no blocks a 155/55/14 sits just inside the guard line. So a small block to get me where I want will be lush as balls. as for clearance at this height I have already cut off the bump stop bracket and will need a small notch to get enough/hopefully enough travel haha. That is 50mm clearance at the moment and I can hopefully pull another 30-40mm out of the rail. See what happens once I make some blocks Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted January 9, 2012 Author Share Posted January 9, 2012 made blocks out of wood and then g clamped the spring/diff/block together because my U bolts wouldnt fit. Boom/with a 20mm cut from chassis and new bumpstop mounts I can have 60mm travel at that height/go 20mm lower and have 40mm travel/tuck 14's/ /be famous like zeb Still have ~60-70mm clearance to lowest point on chassis but my gearbox and xmemebr etc sit pretty low. Anyways, just doing some calcs now to see what I can cut the rail down to and still have enough guts/the same as factory strength. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted January 15, 2012 Author Share Posted January 15, 2012 Sup. Mocked up the cross member and struts today. Notice the baked bean tin spacer. Made oyut of whatever happened to suit ^that is how much Id need to shorten that shock to get it to work haha. New shocks are on the way and a complete new setup is in the pipeline. Also. geometry. LOL Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted February 11, 2013 Author Share Posted February 11, 2013 This is what I ended up with after way too long lying underneath and measuring things/scratching my head/arse. A quick tidy up and some paint and the rear is finished yaaaaay. Now its time to wait for another year for the next update haha EDIT: It looks like the worlds smallest notch in those photos but after a lot of thinking the main reason was to strengthen the rail so it could take a bumpstop load. After removing the bracket and the small cut I made I gained ~30mm. a heap of work for not that much but when your playing with fuck all travel it made a huge difference haha. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted February 11, 2013 Author Share Posted February 11, 2013 Also just bought these. Will use the Tacho for sure and depending on the condition of the speedo will swap to the MPH unit. Id rather stay kph but mine is in pretty shit condition. Will see what it looks like /Joe can you pick it for me in masty town? Quote Link to comment Share on other sites More sharing options...
