VitesseEFI Posted August 25 Posted August 25 11 hours ago, ThePog said: Harder to overthow a tech company probably... True dat….. unfortunately. The car is going to be bloody amazing with this conversion….. watching with great interest. 1 Quote
Alfashark Posted August 26 Posted August 26 Hot dog resonator from V-band to bumper? You've got a bit more length from the collectors, but an 18" hot dog was all I ran from the bend off the collectors to the bumper on ye olde Skoda - Passed wofs, sounded fuuuuuuunky. 1 Quote
ThePog Posted August 26 Posted August 26 10 minutes ago, Alfashark said: Hot dog resonator from V-band to bumper? You've got a bit more length from the collectors, but an 18" hot dog was all I ran from the bend off the collectors to the bumper on ye olde Skoda - Passed wofs, sounded fuuuuuuunky. I snaffled a twin pipe rear exhaust section from a v8/v10 BMW for $20 or something which has some pipework and two rear boxes. I'll probably lay it out the same as the previous setup, two boxes side by side and then out. At least with the V band it will be easier to drop it out and try something else if it does not work.. 2 Quote
h4nd Posted August 27 Posted August 27 Looks great, but I'm surprised at how far forward you're mounting the turbo. I had no idea that cold trans tunnels was such a problem with these Quote
ThePog Posted August 27 Posted August 27 21 minutes ago, h4nd said: Looks great, but I'm surprised at how far forward you're mounting the turbo. I had no idea that cold trans tunnels was such a problem with these You are a funny chap... You should be asking if you can turbo a two stroke. 1 Quote
BiTurbo228 Posted September 2 Posted September 2 My X1/9 was a hoot with the Uno Turbo engine, even at only 1 bar and 130hp (if that, it had a fair bit of blowby). Definitely felt like the power the car should have come with. Yours should be around that as standard too shouldn't it? Quote
ThePog Posted September 2 Posted September 2 Dont know exactly, but it should be around 100kw standard and a bit more with the throttle bodies and exhaust. The old engine was pretty stout, maybe 130hp and yea thats plenty fun, so this should be a hoot. 3 Quote
BiTurbo228 Posted September 3 Posted September 3 If it's one of those bead rollers like I've got then they benefit from some reinforcement. Even with this it spreads apart when trying to run a bead on anything thicker than 0.9mm. it does work, just a pain. I need to make some bolt-in braces at different positions along the jaws to beef that up a bit. 2 Quote
