Found a bit, a Ribe M12 type whatever that is.
Nothing bad but the head gasket around the bad cylinder number 4 is a wrongun, its squished away from the bore.
Also number 2 looks pretty lean, might be the carbs I guess. Who the fuck would want carbs?
A japanese engine is looking more appealing right now.
  • Like 9
  • Replies 216
Cleaned it up a tad
Everything else looks fine, but something was pumping coolant the wrong place..
  • Sad 10
Can anyone tell me what this bit of kit on the engine is?
Mostly so I know it is safe to bin it and block off the hole.
Also there is a blanked off hole where I assume a speed sensor is on some variations down on top of the diff. I may need one to road dyno shit so does anyone know a part number or a vehicle to rip one off?
Been messing with the throttle bodies, exerting my mediocre machining ability to make some spacey bits so the halves are an extra 28mm further apart;
Additionally I have been iterating some manifolds and inlets. Mostly getting them shorter and shorter so they would actually fit with room for an airbox.
I had a roll of PA-CF so started printing what I hope is the final versions of those. Such a bitch to stop it from peeling off the bed though, I have probably solved it with some orientation tweaks, insulating the machine and preheating everything with the heatbed for an hour or so. And drying the filament excessively.
Seems to be working tho.
  • Like 8
