Sign in to follow this
Goat
Requiemk626's c110
Ky i might give aussie a ring tomorrow or in the new year if i order 2 gtr flares will you be keen?
Yeah boe, keen as beans.
Share this post
Link to post
Whut? You can pick up 25DET w/ Gearbox packages for <10k
His 110 is already prepped for an RB so he essentially just has to bolt it in, there's always bits and pieces to do but unless you were paying someone else to do it, I doubt it would come to $10,000.
You can buy a whole R32 or 33 w/ 25T for $10,000.
I mean the total cost of the engine+ancillaries+box etc, and no offense rekemeke but you don't exactly seem confident about cars so I'm guessing shit will crop up you'd need to pay someone to fix. Always budget 3 times as much as you thought and 3 times as long to do it in.
Things like the ecu will cause headaches, you may resort to aftermarket for that, then upgrades blah blah, you all know the deal. I'm confident for 10k plus
Share this post
Link to post
Yer my car knowledge is still shit but better than most starting mechanics apprenticeship helps + workers have offered help very easy going wont be a problem. 10k is very reasonable which will get me there.
If motivation exists in the future for it and it actually gets done i can easily see 15k going into it and finishing it at that level easily.......
Share this post
Link to post
VL gearboxes have gay ratios though, and 32 boxes break behind 25T's with a bit of abuse. Better to fork out for the decent box to begin with than to get coated in gearbox oil all the time.
Share this post
Link to post
Your just trying to show off pictures :lol:
Na i want huge turbs for massive spool noise and screamer for lols
and the gearbox thing will have to do more research but hear people using them with the power im after so hopefully ill get a good one, if it brakes i think ill go 25t
Share this post
Link to post
yuck at turbo
yuck at dcoes on such a new stz engine.
do rb25 non turb with cams that have like 4" of lift, and itbs
Share this post
Link to post
I'd be keen for the flares too if ya still looking at getting them. the Oz guy that has made them also has front lip, spoiler & grills.
Share this post
Link to post
You looked under the ass of it boe?
Because if your plan is to run coil-overs on the rear you're going to have to make some new suspension mounts. It runs separate shock and spring and I'm not sure I'd rely on a coilover in the place of where the shock is mounted.
Share this post
Link to post
Yep have looked underneath it. Near 45degree angle but should be fine have researched into peoples past experiences. Will mount where shock sits maybe have a better look tomorrow to see if i can mount a little more vertical.
Share this post
Link to post
Would probably be a better idea to fabricate a mount into where the spring sits, it's a lot more central to the arm.
Share this post
Link to post
I'm just running Lovells in the rear with NOS Air Adjusties
Edit: That looks alright, actually. My only concern would be the rate of both spring and shock, the spring rate of the standards and of the lowered ones is pretty firm and it was a sloppy ride from factory :? Haven't used mine with the new rear springs in it.
Share this post
Link to post
Just as a side note, the 210 mounts in a similar place as the 110 shock but is McPherson strut rear, and they're upright as opposed to angled.
Share this post
Link to post
if you are looking for where to get POR15 look on their nz site, has a list of suppliers. Works out at about $60-70 a litre depending on how much you get
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
