NewGuy Posted October 3, 2007 Posted October 3, 2007 As i am getting my petrol tank sorted out which could end up costing me more than it is worth, i need to look at getting a new fuel sender gauge unit. What will be my best options? Something that is also easy to install etc? Quote
Mike-e Posted October 3, 2007 Posted October 3, 2007 wheres the tank mounted? sight glass/hose and 2 90 deg fittings ftmfw Quote
Hemi Posted October 3, 2007 Posted October 3, 2007 ^^ thats the best shit ive heard ever , umm well unles yove got a norm tank ud probably have to get somthing that you can calibrate i would think ??? Quote
Raizer Posted October 3, 2007 Posted October 3, 2007 $60 at repco got me a trisco fuel gauge, came with adjustable sender set up etc Quote
NewGuy Posted October 3, 2007 Author Posted October 3, 2007 $60 at repco got me a trisco fuel gauge, came with adjustable sender set up etc So did you get a sender unit and a Gauge? How was the sender unit to be mounted? Quote
NewGuy Posted October 3, 2007 Author Posted October 3, 2007 wheres the tank mounted?sight glass/hose and 2 90 deg fittings ftmfw Original boot location mate Quote
CaMpylobacter Posted October 3, 2007 Posted October 3, 2007 so you're using factory tank? thoght about finidng a factory replacement sender, or, a secondhand number from a wrecked car? perhaps compare with tc, stag, toledo, or herald equivalent parts? Quote
Raizer Posted October 3, 2007 Posted October 3, 2007 $60 at repco got me a trisco fuel gauge, came with adjustable sender set up etc So did you get a sender unit and a Gauge? How was the sender unit to be mounted? Yeah sender and gauge, just one of those plain black faced ones. Has a round plate with 6 holes in to mount to the tank (i modded the factory escort mount though) and you need to cut the rod the floats on to the length need (covered in the instructions) Can go in the top or side of most tanks Quote
NewGuy Posted October 3, 2007 Author Posted October 3, 2007 so you're using factory tank?thoght about finidng a factory replacement sender, or, a secondhand number from a wrecked car? perhaps compare with tc, stag, toledo, or herald equivalent parts? You have got to be kidding. They are all fucked any how. Quote
NewGuy Posted October 3, 2007 Author Posted October 3, 2007 $60 at repco got me a trisco fuel gauge, came with adjustable sender set up etc So did you get a sender unit and a Gauge? How was the sender unit to be mounted? Yeah sender and gauge, just one of those plain black faced ones. Has a round plate with 6 holes in to mount to the tank (i modded the factory escort mount though) and you need to cut the rod the floats on to the length need (covered in the instructions) Can go in the top or side of most tanks Mint ill check out ripco tomorrow, and talk to my engineer. Hes gunna put something a little thicker so if i do put a sender unit in its alot more beef to bold into. You have any pics of the model you have? will be going intot he top of the tank. Quote
Raizer Posted October 3, 2007 Posted October 3, 2007 Um i can take a pic of the gauge now if you want, im not pulling the sender out of the tank to get you a pic though! lol / they probably wont have one in stock, they will need to order them more than likely. Quote
peteretep Posted October 3, 2007 Posted October 3, 2007 so you're using factory tank?thoght about finidng a factory replacement sender, or, a secondhand number from a wrecked car? perhaps compare with tc, stag, toledo, or herald equivalent parts? You have got to be kidding. They are all fucked any how. its not worth looking into other triumphs to compare?? surely someone would have something Quote
NewGuy Posted October 3, 2007 Author Posted October 3, 2007 Time hassel etc im pretty sure theya re a unique tank made for the car. The dolomites any how. Even the standard dolomite had a different size tanka nd all. I need a new gauge sender anyhow. Hope the tank repair does not cost to much and it actually lasts etc. Quote
Raizer Posted October 3, 2007 Posted October 3, 2007 relooking at your project thread the repco gauge wouldn't look too out of place in the stock spot Quote
NewGuy Posted October 3, 2007 Author Posted October 3, 2007 relooking at your project thread the repco gauge wouldn't look too out of place in the stock spot Mint cheers for the help Boe Is that the unit? does it have a backlight? Also is it 2inch? Quote
Raizer Posted October 3, 2007 Posted October 3, 2007 relooking at your project thread the repco gauge wouldn't look too out of place in the stock spot Mint cheers for the help Boe Is that the unit? does it have a backlight? Also is it 2inch? All good boe. Yes, yes and yes Quote
NewGuy Posted October 3, 2007 Author Posted October 3, 2007 Just got the tank back. $174.50 Eek I think its kinder expensive but yea what do you guys think ? Quote
treggo Posted October 3, 2007 Posted October 3, 2007 Depends what they had to do really. I guess there is added risk for them doing something such as a tank etc. Quote
CaMpylobacter Posted October 3, 2007 Posted October 3, 2007 had to be done..... should last too. they'd let you know if it was rotted to oblivion Quote
