Joe's Jag
  • Replies 108
  • 4 years later...
  • 4 years later...
Motoring writer Harry Metcalfe just completed the build of a V12 Jaguar XJC with a manual conversion. His V12 originally ran the early injection system which was problematic and daft*, so the car's now converted to an aftermarket ECU and later Jag injection from the 6.0 V12s. He's also running a shorter diff. With a couple of intake and exhaust mods and dyno tuning, the rebuilt standard engine makes ~350hp.
*the original system apparently simultaneously fires the injectors on groups of 3 adjacent cylinders, which would be at different points in the combustion cycle. I guess it just fires the injector group multiple times, so each cylinder gets fuel during its intake stroke. No wonder the fuel economy was terrible. :shock:
Jag loving mate had an XJ12 for a while.  Carbed one. He discovered that the bolt pattern for the puny 1 1/2 in Solexes is the same as 6 cylinder SU's.
Bolted on 4 X 2in SU's. Never dyno'd it but the improvement was startling.  Fuel comsumption otoh was frightening. Up past Oxford cruising at highly illegal velocity, you could watch the fuel gauge dropping.
What Joe didn’t add to his story was this thing also decided to pump all it’s fuel out in the engine bay, thankfully avoiding a fire. (But also causing us to have to walk back and find a jerry can of petrol)
It also (unsurprisingly, being British) dropped all it’s oil out on KYs garage floor and henceforth became known as the Exxon Valdez.
Ooo, someone's selling XJS V12 manual conversion parts in your neck of the woods, in case yours have seized up or something..
https://www.trademe.co.nz/a/motors/car-parts-accessories/jaguar/listing/4105559969
I wonder how someone can be unable to drive stick any more but still able to get in and out of an XJS. :scratch:
I can investment cast them for you Joe if you'd like.
Totally doable yourself, just be prepared to spend a load of time on it and have some failures along the way. I'm still screwing up the odd casting and I've been doing it for 7 years now.
Feel free to hit me up if you want any advice.
