Testament's '74 Fiat 124 Coupe
  • Replies 84
because old man pants decided to take out the on/off 6 puck solid centre 200mm clutch and 6kg flywheel and swap to a OEM cast iron flywheel, but modified to take an early integrale 8v 230mm push type clutch and pressure plate I found on amazon for a bargain after extensive part number googling
but nothing too simple of course. OEM flywheel from fiat 131 is for a 215mm clutch so the friction face is too small, and all the dowels and bolt holes are in the wrong spots by just a little bit.
so had to machine it down to flat on big lathe at work, then machine a step with 230mm diameter, then setup in the mill and drill and tap for dowels and bolts offset to the original clutch ones, and make some new dowels to suit.
