I( could swear I scribbled down some notes about what the supposed ideal angle is of port to inlet to exhaust valve face, but can I find it? Though that's probably another of those ones that varies considerably based on what sort of dimensions your chamber has as it's all about shooting the inlet air cleanly across the top of the exhaust valve. Would be secondary to proper real-world testing.
I did find some other scribbled notes that may or may not be helpful.
  • The 'ski jump' thing on the short-side radius is for additional tumble, supposedly to help economy. One bod thought that for a performance engine you wanted to do away with that to get more flow around the valve like Roman's NACA duct thing.
  • Cosworth FVA pioneered tumble geometry. It had 20deg inclined valves (40deg included angle) and 20deg port inclination to valve.
  • Cosworth DFV was more successful. It had 16deg inclined valves (32deg included angle) and 20deg port inclination to valve.
  • Both had ports that were just straight-bored into the head directly to the valve.
Need to chuck that into CAD and get an idea of what they were running in terms of transition from port to inlet valve to exhaust valve face. Trying to work it out is making my head hurt :D
Edit: ah, it was in the pic I shared.
Supposedly, having the included angle of the valves plus the angle of the intake port relative to the valve equal 90deg (or close to it) is beneficial for avoiding that vortex over the exhaust valves. The top picture has a 95deg angle and seems to model out well, and the other has 65deg and seems not to work. Though that doesn't add up with the DFV or FVA working well so who knows man! Maybe a rubbish tumble 4v head is still good enough to outrace a great swirl 2v head. Maybe all of this only matters for economy.
6 hours ago, BiTurbo228 said:
Interesting that you said the head wasn't really doing much by the point it let go. Is that the new steep-port head?
From what I understand, tumble is pretty sensitive to the port angle relative to the chamber. If it doesn't match closely enough you get a recirculation dead-zone by the exhaust valve that messes up your homogenisation.
No idea if that's what your new ports are like, but would be interesting to check.
Edit edit: Just gone on a bit of a jaunt through the FIA historic database, of which some of the 90s Group A homologation papers give valve included angles and port inclinations. Seems OEMs are doing whatever they want. Probably suggests that either no-one had got this cracked by the 90s, or there's more variables involved (I'm going with the latter).
  • Replies 725
You reckon it'll still make more power than a 20v with only 3 pistons?
Sucks to see man. good luck for what's next.
Be interesting to see if there's any clues showing on the other pistons/rods/bolts that failure was fairly imminent.
  • Haha 1
Easily. I suggested taping up the holes and getting it going again.
  • Haha 2
Ouch! Off to Valhalla for that 7A block. Did it catch fire?
It'll be interesting to see how much it changes with the normal rod ratio and the new head.
This is true ^  seems whatever you do to a 7a it still sucks.
no doubts it would still make more power than a silvertop.   it still turned over fine by hand like there was nothing wrong.  if it hadn't taken out the main gallery from oil pump.  could have bolted a bob weight to the crank, taped up the holes and carried on.
@Truenotch  Yeah  big fireball on rundown, as above rod took out the gallery from oil pump to oil filter. so it just pumped all the oil out onto the headers. along with the spray off the crank.
Calmed down a bit by the time i got to it.  but was better to spray it before it caught onto anything else.
yeah it always made a bit more on the other bottom end. this one was a little bit lower compression though
he would have it covered on social media though
@BiTurbo228
not much science, but i took a picture when washing it.  end of the day the last part of the port is still within factory constraints.  just half of the turn is gone
I'm thinking i need to play with the ratios more than anything.  at the seat vs further up the port.  port entrys  look really big in the pictures. but is just the angle that makes it look that way
To go smaller will need to make new inserts.  so the move would be just to go full ham on the current ones to see what it does.  I haven't had a chance to look at the dyno stuff and data properly yet.
but im currently leaning towards they need to be bigger in places.
47 minutes ago, GARDRB said:
Lucky you know a fire guy. @Dudley would have stood and watched you put the fire out if he was there
Sometimes I wonder why didn’t krisp
simply not blow his rod out the side of the block? That way he wouldn’t be in this situation
  • Haha 2
Man I'd love to see all of this stuff on a wet flow bench. Would be dead interesting.
I'm still intrigued by the NACA duct thing in Roman's 4GR head...
Oh, and if it means anything the FIA papers think the included angle on a 4AGE is 50 degrees, meaning something like a 40deg port-to-valve angle would be what the book says is optimal for whatever it is they're optimising for. Would probably help if I had the rest of the book rather than just that one snapshot...
Chop up the dead block and make a couple of single cylinder test rigs? Bung em into a motorbike so you can still use your rolling road? Scope creep? Never heard of it... :D
The gold standard for a starlet engine swap used to be about 3 hours back in the day. I imagine you would have no trouble smashing that!
Haha not quite,  has a few more things to disconnect than a k series.  Plus I actually despise mechanic work.
Is up and running again on the og bottom end
So internet scientists,  what broke first the rod bolt or the cap?
Some one suggested the cap broke first,  hence why the end of the rod bolt is bent.  which makes sense, as would have peeled the remaining cap off    the cap is broken through the weak point where its been machined for the bolt and there is a sharp edge
Going against that theory.  the angle of the break in the bolt suggests the bend in the bolt is the wrong direction, as per bottom picture.   this is assuming what's left in the rod didn't spin around after the fact.
The big dent in the head of the bolt and the flat spot on inside just below the bend, suggest was plausible the bend happened after the bolt broke
  • Confused 2
