discussion thread:
picked it up a few years back. as an unfinished project, had a 20v 4age sitting in the engine bay, a pile of parts in the back, and looking pretty rough. heres what it looked like after i picked it up:
after closer inspection , turns out the 20v was rooted. so it was binned and replace with a 16valve smallport:
at the same time the engine mounts were redone and gearbox mounted. then a hilux diff, sourced from a local car dump, was modified and installed along with ae92 brakes. king springs and shorter kyb shocks, went in the front. the rear got shortened stock shocks and some cut nissan sunny front springs. 2" stainless exhaust was made from 2nd hand stainless complemets of fonterra. the coby extractors were choped up, and modified with old exhausts from the car dump. made into a much better 4-2-1 set. along the way when i could be assed, some of the rust was fixed.
this is where the project slowed right down, since panel work sucks. but with car running and driveable it. various panels missing and doors that wouldnt shut. it made for some amusing late night country road driving. 2 seats a steering wheel and an engine was enough.
finally after a few years pissing around and bitching at the bro to paint it, it had a new coat of paint:
the plan was to finish putting to together, then go for a cert. till i decided it needed some quad throttles. deciding to do something a bit diffrent, a varible runner setup was made. along with fiberglass duct/airbox, new radiator installed, stock ecu was replace with a lem g3, and tuned:
car was booked in for a cert, but cert guy canceled. at the same time i wasnt too happy with the suspension setup. so had yet another stupid idea to do a coil over setup front and maybe rear. front setup was first, along with choped up ep82 camber plates and some rca's:
with that complete. i currently have some 100mm holes, cut in place of the original rear shock mounts, and some 100mm tube sitting in place for the rear setup, more to come.. :
  • Replies 243
done some more on the rear suspensoin setup. spherical bearings in the top, and some excessive bracing:
just need to weld some new mounts on the diff, and its done.
rear supsension is finished, handles way better than the old setup.
trimed some holes in the air duct and put the strut bar back on.
another pic of the variable runner setup. in the high rpm stage. the link switchs them at 5500rpm. they are powered by a kp windscreen wiper motor.
low
the 4a had a blowen headgasket, couldnt help myself and done some back yard headwork while head was off. removed the material shelding the valves and made a raduis down to the vavles insted of the step (not showen in the pic) dunno if it made it faster or slower.
thinking about buying some new rims, since the ones on there are pretty rough. threw the 16's off my other car on, to see what width and offset is going to fit. actually look alright but want some 15's
been awhile since i updated this.
first up i got a supra lsd from spencer (cheers boe) to replace the hilux one. witch wasnt much better than an open diff. fitted it into a 4.3 open diff i had, i machined the ends of the diff down to fit the open diff bearings. then figured out later i could have just used the standard bearings, the lsd version head uses. but first option was cheaper and faster anyway. next problem was the supra lsd had a slightly different offset, so the backlash couldnt be adjusted enough, as the adjuster bottomed out. machining the first few threads off the adjuster fixed the problem tho.
can see in the pic the adjuster sticks out quite far, other side is the opisite. but still enough threads in there to be all good.
after almost a whole weekend pissing around installing it, i was pretty gutted to find it was almost as bad as the hilux lsd. turns out it was basicly the same as hilux one inside. maybe just the preload spring was stronger. didnt have the apart at the same time to compare. defintly no ramps tho.
because one wheel skids suck, i spent some more cash and got a modified hilux one, with ramps and shit in it. mean- well worth the money
modified vs supra
got me a ae86 quaife quick rack. some slight modifcations and now its 2 turns lock to lock insted of over three. steering is a little heavy, but it drives like a gokart.
still waiting for my new rims to arrive, should be here in a few weeks hopefully
has nearly passed cert, just need clean wof and driveshaft to be sorted.
has cert, wof and reg!
going back to a single throttle intake, mostly due to all the crap going thru the motor. rather than trying to find an over priced smallport inlet. im making a custom one. shouldnt loose much power over the quads.
mid part of the runners. tapered for velocity:
more progress tomorrow,.
new intake had a nasty vibartion problem i couldnt fix. so quads ftw
shit since im trying to resist the urge to turbo it, but could do with a bit more power:
crusty ones are the orginal smallport cams vs kelford billets. currently has bluetop cams.
  • 4 months later...
new rims!
these pics dont do it justice:
will update the other changes and post some better pics another day.
had to make a few changes to make the work's fit. changed back to 4x 114.3. as i had changed to 4x100 and fwd offset, because it was cheap way to do brake upgardes and make hilux diff fit at the time.
front hubs swaped back to standard. new pug rotors and bracket made for caliper:
diff needed to be shortend 15mm each side. was going to biff some rn25 axles in and shorten case more. but couldnt find any at the time. so had a go at shortening some myself:
^ that shits hard, to hard to machine. so made this to get thru the case hardening
case shortening, plus redone the 4 link mounting points to move the diff back a little and add some adjustment
rear brakes are, s13 rotors and the same ae92 calipers that was on it before, plus new brackets made.
remade the exhaust today as the old one was 20mm from the ground! after lowering more and the 195/45 tyres.
diff mods seem to have worked as it was getting good traction off the line.
had thoughts of putting a turbo on it, but think i'll just rebuild it. maybe with some higher comp pistons. current engine is getting a bit tired
since rebuilding thought i better put an air filter on it so it lasts awhile, will mod the fiberglass duct to fit around it. plus blacktop flywheel
machined the front part of the pulley off as its not needed + brake reso relocator plate, to make room for filter
got some more of this stuff to machine new trumpets from, test run on the old variable slides, 1.5 deg taper, big bellmouth. new ones will be 2 peice to hold air filter backing plate
started on new extractors. current ones are 4-2-1 and tuned to lower/midrange. so don't work so great with the cam's. plus they are a bit hagard. progress so far:
gonna also slide the engine accross 10mm or so, to the exhaust side, before i start mocking them up on car. witch will gain me some more room for airfilter / intake. easy the way the engine is mounted.
finally got some time to do a little more on extractors. theres no room under car. so runners go forward and loop back under to gain some length. trying to keep everything even as possible.
took it around puke last weekend. was pretty hilarious in the rain.
ripped them apart countless times. almost there now
still sussing out no# 4, will be a bit diffrent than in the pic. as its too close to cas. plus run out of bends.
