DavidTheCreator Posted March 3, 2007 Share Posted March 3, 2007 im wanting to put my battery in my boot, how do i do it? where do i buy a case and so on from Quote Link to comment Share on other sites More sharing options...
Hemi Posted March 3, 2007 Share Posted March 3, 2007 case from supercheap , thick cable from whatever ... kill switch( if you want) , wire , hit up callard he works at a electrical supply shop Quote Link to comment Share on other sites More sharing options...
lowlancer Posted March 4, 2007 Share Posted March 4, 2007 Probably easiest thing I've ever done to my car get welding cable, tis WAY cheaper than real battery cable. Just get case from supercheap, screw it down in boot, cut lead to length, solder on new lugs on the ends, lay under carpet and connect to starter Shouldn't cost more than 120 or so Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted March 4, 2007 Share Posted March 4, 2007 less than 30 min job, $25 for battery box from - super cheap auto (about $17 on special) $50 approx for 35mm squared cable - electrical wholesaler or boc (welder cable) 6 metres or so $5 max for 4x 35mm squared lugs - electrical wholesaler measure length, crimp lugs onto cable run in car and connect easy as job Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted March 4, 2007 Share Posted March 4, 2007 small dry cell batterys are awsum, around $100 and can sit on any angel plus easy to hide and no box needed. got to be fucking careful about routing that starter wire!!! any earth short and ur car will most likely catch fire Quote Link to comment Share on other sites More sharing options...
peteretep Posted March 4, 2007 Share Posted March 4, 2007 they use the dry cell ones in boats and stuff dont they? they can be recharged after sitting for long periods? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted March 4, 2007 Share Posted March 4, 2007 holla at routing cable. Shorted out mine once, lols hard, where lols=me screaming like child Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted March 4, 2007 Share Posted March 4, 2007 not 100% sure about the charging, mine holds charge mint as, spins ova zetec and a good speed. recomend them a Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 4, 2007 Share Posted March 4, 2007 they use the dry cell ones in boats and stuff dont they? they can be recharged after sitting for long periods?Deep cycle, made to be run flat alot/left sitting and still charge sweet as Quote Link to comment Share on other sites More sharing options...
ProZac Posted March 4, 2007 Share Posted March 4, 2007 Its a good idea to get a marine starting battery if your car's lowered, or see some hard use. They're alot hardier and will survive the vibrations and knocks much better. Quote Link to comment Share on other sites More sharing options...
treggo Posted March 17, 2007 Share Posted March 17, 2007 hey would having the cable longer make it draw more current? :edit: sorry to dig up old thread. Quote Link to comment Share on other sites More sharing options...
sholdowa Posted March 17, 2007 Share Posted March 17, 2007 Yes. Whatever cable you use has some resistance. The longer the cable run, the higher the resistance and the more current is converted into heat Current = volts/resistance, so as the voltage stays (approx) constant, the current drops as the resistance increases. Quote Link to comment Share on other sites More sharing options...
Hemi Posted March 17, 2007 Share Posted March 17, 2007 should drop bugger all yea cable does have some resisitance but hell unless it goes around the car 8 times i doubt it should make a diff. deep cycle are made to discharge and charge alot (have much thicker lead plates) , but this means it dont have as much cranking amps , and seeings as your car is only usuing power when running , the altenator supplies all the power anyhow , id say so gellcell and put a main line fuse near the batt somewhere incase it somehow earths out and decides to put 400 odd amps through the cable in 1/4 of a second Quote Link to comment Share on other sites More sharing options...
