Torque settings and Clearances 2l pinto
Gaz
Torque all in lb f ft
Mains caps - 64.5-74.5
Flywheel - 46.5-50.9
Big end bolts - 29.7-34.7
Oil pump - 12-15
Pump cover - 6.4-9.3
Sump
1st - 1.4
2nd - 5.7
3rd - 7.5
Head
1st - 15-30
2nd - 36-51
3rd (after 20mins) - 54-61
4th (after warming up) - 70-85
Valve clearances (cold) mm
Inlet - .008 (0.20)
Exhaust - .010 (0.25)
Sparkie gap - .025inch (.60mm)
18mm plug
Contatcs/points
.45mm Motorcraft
.45mm Bosch
Firing order = 1,3,4,2
Give her 8° BTDC @ 800rpm
