Hilux LSD diff identification
Gaz
on the chassis build plate next to axel it'll have a number like G282
the last digit 2=2pinion open diff. 3=2pinion lsd. 4=4pinion open diff. 5= 4pinion lsd.
g = series of diff
and second number means the ratio.
if its a nz new ones then plate prob wont say sh!t all. the other way i've heard is removing the driveshaft and theres paint on the input flange but i'm yet to see it or a code saying wat they are.
basic check (rule of thumb, aplies to all)
turn an axle and the other should go the same way, (as it shouldnt go backwards, thats open wheeler) or hold one axle and try to turn other. it will not be posible by hand.
DONT BE STUPID AND JACK UP ONE SIDE OF A CAR AND DRIVE IT TO SEE IF ITS GOT ONE!
its only for when the diff is out of the car. (had to say)
Ratio is turn driveshaft and count the axle turns. for example, one turn of the driveshaft input will give 4.5 if the axles. high number will have the axles spinning fast (eg 4.111) low number will be low speed (eg 2.5)
Low numbers are best in high torque, low revs engines (eg V8s and deisels) provide great fuel economy, top speed. lose responsiveness.
High numbers are best in low torque, high rev engines(eg 4AGEs, Rotarys ect) provide mind bending acceleration, lose top speed.
thats a realy bad summary, as it depens on gearbox (5sd/6sd) and tyre size. a 215/45R17 has a longer rolling diametre to a 215/45R14. so the smaller tyre is as effective as changing the diff ratio to a higher one.
  • 6 years later...
i found this somwhere on the net. it should be helpful to u guys....
Identifying Toyota Hilux & Hiace Differentials
The Toyota Hilux has ID plates fitted in the engine bay, while the Hiace has them fitted near the
base of the front seats. In each case one of the plates will have the 'Axle' code originally fitted to
the vehicle.
As an example a RN25 Hilux manufactured during the 2/74 has the 'Axle' code "G142".
The letter "G" signifies it has a "G" series differential and therefore an 8" diametre crownwheel.
The next two digits, "14", nominate the ratio, which according the ratio table below is 4.875:1.
Many of the ratios have not been fitted to Australian vehicles nor are they all sold here as an
aftermarket item. The 4.875 and above ratio centres have a slightly different crownwheel position
on the centre. So if ratios below 4.875 are to be fitted then select a diff with a ratio below 4.875 or
vice verca if shorter ratios are to be used.
Two suppliers who have crownwheel & pinion sets are Sunstate 4WD & Jack McNamarra Diffs.
The last digit, "2", is for the type of centre, in this case 2 Pinion & Open centre as per the centre
table below. The factory LSD is a clutch pack type, while aftermarket suppliers offer these, plus a
wide range of other types.
RATIO TABLE
Code Ratio
Code Ratio
Code Ratio
Code Ratio
01
3.300
13
4.790
25
4.556
37
3.583
02
3.360
14
4.875
26
5.571
38
3.417
03
3.545
15
5.125
27
3.364
39
3.154
04
3.556
16
5.286
28
4.300
40
5.375
05
3.700
17
5.600
29
4.100
41
3.308
06
3.889
18
5.714
30
3.727
07
3.900
19
5.833
31
3.909
08
4.110
20
6.167
32
6.591 or 4.807
09
4.222
21
6.667
33
7.503 or 5.583
10
4.375
22
6.780
34
6.781 or 4.786
11
4.444
23
6.833
35
7.636 or 5.600
12
4.625
24
7.640
36
4.778
CENTRE TABLE
Code Centre Type
2 pinion open centre
3
2 pinion limited slip centre
4
4 pinion open centre
5
4 pinion limited slip centre
The Toyota Hilux & Hiace Differentials
The Toyota Hilux and Hiace differentials are all similar in design. They feature an 8" crownwheel,
31 spline axles and large bearings. They have ample capacity for an Escort and a converted Hilux
diff will weigh about 60kg.
Common ratios to be found at wreckers in Australia are from 4.110:1 to 4.875:1. The taller ratio of
3.7:1 was delivered with V6 vehicles in the USA. Aftermarket suppliers in Australia have gear sets
of 3.5:1, 3.7:1 etc. available new.
The closest fit for an Escort is the Hilux 2WD diff from RN10, RN15, RN20 & RN25 models
manufactured during the first half of the 70's. Each of these has the same spring centres (940mm)
and overall width (1350mm) as an Escort. The spring platform width is equal to the MkII Escort at
60mm but wider than a MkI which has 50mm width springs.
What needs to be modified ?
Axle Shafts and Flanges
These axles have five M12x1.5mm studs on a 4.5" PCD and will require restudding to match the
MkII Escort pattern of four M12x1.5mm studs on a 4.25" PCD. The Hilux studs are longer than
Escort studs. The MkI Escort has 7/16"UNF studs on a 4.25" PCD.
The drum/wheel location boss on the Hilux axle is Ø67mm compared to the Escorts Ø63mm. If
Escort drum brakes are to be used then the boss must be machined down. If an upgrade to larger
drums or disc brakes is chosen then the boss may need changing in size to suit the alternate drum
or disc centre hole.
Some Escort mag wheels may fit over the Hilux boss but standard wheels and some mags will
require the boss to be Ø63mm where it protrudes out further than the drum or disc and into the
wheel.
If alternate discs are fitted over the axle flange this will increase the overall width of the diff by the
thickness of the disc bell on each side of the diff. So if discs with a bell thickness 7.5mm are fitted
then the overall diff width will be 1350+7.5+7.5=1365mm. Check your tire clearance to the guards
and track width requirements. Most of the axle shaft fitted to the RN10-25 models have sufficient
spline length for the axle to be shortened a small without the need for re-splining, but work out
what you need and measure the axles before purchase.
Brakes
The Escort drum brake backing plates will need the centre hole size and bolt pattern changed to fit
over the Hilux bearing carrier. The backing plate will need a spacer behind it so that the drum
properly covers the brake shoes.
Upgrading the brakes to discs has been done and reuse of the Hilux drum system may be possible.
Differential Centre
The ratio and type of the centre that is factory fitted to RN10-25 Hilux may not be suitable or
serviceable considering the age. Options are to fit a diff centre from another later model Hilux or
Hiace that has a suitable ratio or Limited Slip centre for example.
Other options are to fit aftermarket ratios or Limited Slip Differential centres and new bearing and
seals.
If the chosen ratio is different to standard and an accurate speedo is required, the speedo accuracy
will need checking and correcting.
Differential Housing
If Escort drum brakes are retained the handbrake linkage brackets and hydraulic line bracket will
need fitting to the Hilux housing.
If the factory style anti tramp rods are to fitted then these will need fitting to the Hilux housing at
the correct angle relative to the spring platforms.
For originality sway brackets would also need fitting to the Hilux housing at the correct angle
If discs, tyre clearance etc. dictate shorter axles then the housing will also have to be shortened by
an equal amount on each side.
With the exception of tramp rods, the brackets can normally be cut from a donor Escort housing.
Shackles and Shackle Plates
The RN10 - 25 Hilux housing axle tubes are Ø65mm and 5.5mm thick compared to an Escort axle
tube at Ø63mm and 3.2mm thick. The Escort shackles fit over this housing, alternatively the
slightly larger diameter Hilux shackles will fit through the Escort shackle plate.
The MkII Escort shackle plates will not require modification to use this Hilux diff housing.
Spring Platforms
To prevent rapid universal joint wear and tailshaft vibration, the operating angles of front and rear
universal joints need to be similar, eg: less that 1° difference in operating angle.
The angle required will varies depending on whether anti tramp rods are fitted and the
curvature/rating/ride height of the leaf springs. Anti tramp rods and stiffer leaf springs reduce the
amount the diff nose lifts under power where as leaf spring curvature and ride height alter the
static position of the diff nose.
The angle of the spring platform to the pinion needs to be checked and altered, if necessary, by
relocating the spring platforms around the axle.
If this diff is fitted to MkI leaf springs, the 50mm wide MkI Escort spring platforms will need to be
fitted to the Hilux Diff.
Tailshaft
The 1 peice Escort tailshaft that has replaceable universals has the same universal as most of the
Hilux/Hiace units, but the tailshaft will need shortening and a Hilux flange fitted to the universal.
Other Hilux & Hiace Diffs
Later Model Hilux 2WD
The later model, particularly 80's on, 2WD hilux diffs are to wide to be useful in an Escort fitted
with wider tyres. The axles do not suit re-splining as they are machined down behind the existing
spline for too great a distance.
They may provide the ratio you are looking for though.
Hilux 4WD
The Hilux 4WD diffs are generally 20mm narrower than an equivalent year 2WD diff. Some of the
axles have an extra length spline that may be shortened without the need for re-splining, in
particular check out the RN46 manufactured around 4/83. All 4WD axles have 6 wheel studs and
can be re-drilled for an Escort stud pattern without the need for welding up the old stud holes.
The 4WD housings are the least suitable as they are step up in diameter toward the centre and will
cause mounting hassles for brackets and shackles.
The 4WD centres will in some cases be Limited slip units and may contain suitable ratios.
Hiace
The Hiace diffs are all to wide for an Escort. The housings are the same style as the 2WD Hilux but
the axle tube dimension is 68mm x 62mm oval and 4.5mm wall thickness. Use of this housing
represents a small weight saving which may be cost effective if the 2WD housing for your
application requires shortening and other alterations.
The Hiace centres may also have the ratio you are looking for.
The mid 90's Hiace is fitted with a wheel stud that has extra spline length. These may prove useful
for a disc brake setup.
