TOYOPET Posted June 22, 2007 Share Posted June 22, 2007 if its a good deal then i could be keen! sounds like a mint idea. you could try the guy who painted my car, took him about a month to do but was a good job, and cheap. he is in ngarawahia, pm if you want his details he also does warrants and any mechanical repairs etc. Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted October 19, 2007 Share Posted October 19, 2007 Just bumping this bad boy thread back into action cos i need some advice from the painting guru's Looking to paint my engine bay this weekend, once its in primer, what grit should i sand it back with before i go for my good coat? Also, looking to do 4 or so coats, should i sand in between coats? If so what with? Love you Quote Link to comment Share on other sites More sharing options...
gtrefinishers Posted October 19, 2007 Share Posted October 19, 2007 first question is what are you painting it with 1k enamek 2k base clear? spray cans? Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted October 19, 2007 Share Posted October 19, 2007 All i know is that its 2 pot or something, and with a small compressor haha. I can feel this is going to be a disaster. Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted October 19, 2007 Share Posted October 19, 2007 400g should be sweet Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted October 20, 2007 Share Posted October 20, 2007 Mint thanks, a guy told me that when i do my good colour, because its 2 pot after 10-15mins or so it should dull off. (like an egg or something..) And when it dulls thats when i should shoot the next coat. This right/any other tips? Quote Link to comment Share on other sites More sharing options...
gtrefinishers Posted October 20, 2007 Share Posted October 20, 2007 if your using base coat with a 2k clear have about 10 mins between base coats then bout 15 before you clear if its just a sloid 2k just leave bout 10-15 between coats and do 2-3 coats depending on how transparent the colour is Quote Link to comment Share on other sites More sharing options...
dylan Posted November 13, 2007 Author Share Posted November 13, 2007 just a couple of questions im going for some ppg 1k laquer when buying it what do i ask for like are base coats and top coats two different types of paint or is the top coat clear??? Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted November 14, 2007 Share Posted November 14, 2007 Base coat = usually a dark coat which covers the primer (check my mini thread for that ugly dark green colour) then you spray the top coat, which will be the final colour (which is sorta "transparent" which is why you spray it over a darker coat of the real colour, else you get weird streaks etc from a light primer coat underneath) Then you spray clear over that. Just tell them what you're after, they'll sort you out, personally when using metallics the base/top then clear is easy cause you can make sure you have covered everything before spraying the top coat. I hope that made sence, I've had afew beers Quote Link to comment Share on other sites More sharing options...
dylan Posted November 15, 2007 Author Share Posted November 15, 2007 cheers man i just had another look at the mini thread and ive got a couple more q's for ya lol um so i understand you used 3 base coats 3 top coats a two clear? what im wanting to know is can you say once you have done your 3 base coats leave it overnight and then do top coats or does it still have to be tacky and does the same apply with the clear?also did you wet and dry between any of that?also i think you mentioned somewhere that you used 2k clear over the 1k whats the advantage of this?........... hope that made sense lol Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted November 15, 2007 Share Posted November 15, 2007 afaik you can leave the base and spray the top coat the next day but don't quote me on that, just ask the guy you buy the paint from. My uncle did it that way and it turned out fine though Yeah I used 2k clear cause I already had heaps and it was cheap (resene) I think I did 4 coats of clear and only 2 on the roof cause it was already 2k and was nice and wet/glossy Better off doing more lighter coats of clear till you get the hang of spraying a nice wet coat for final, don't get carried away and just wet sand and buff if its orange peeley cause its a shit load less hassle than getting runs out afterwards (spraying a wet clear is alot more prone to running on you as its full of thinners) I didn't sand anything during the process. Also make sure you get the body clean with grease remover first cause even finger prints etc can make it bubble (had this happen before) How far away are you from painting? Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted November 15, 2007 Share Posted November 15, 2007 Only advantage of doing it that way is that its easy to paint single pack stuff, and alot less fucking around with hardener, just throw the thinners in, mix then spray. It sorta dries real quick and goes matte and doesn't seem to run as easy as 2k which is great for noobs like us Quote Link to comment Share on other sites More sharing options...
Rusted Posted November 15, 2007 Share Posted November 15, 2007 Also 1K is OS. Acrylic is Vintage. Quote Link to comment Share on other sites More sharing options...
treggo Posted November 15, 2007 Share Posted November 15, 2007 Yuh your true OS if you use 1k Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 15, 2007 Share Posted November 15, 2007 whats good for cleaning vinyl before painting it, ive used meths and thats ok but deosnt get the hard stuff. I think its mostly oily hair that causes the paint not to stick Quote Link to comment Share on other sites More sharing options...
gtrefinishers Posted November 15, 2007 Share Posted November 15, 2007 Yuh your true OS if you use 1k hahhaha i like it!!!! but wat bout enamel???? and a brush hahha 'henry ford' did it Quote Link to comment Share on other sites More sharing options...
Snoozin Posted November 15, 2007 Share Posted November 15, 2007 A pot of Taubmans and a roller should see ya right. Quote Link to comment Share on other sites More sharing options...
mikuni Posted November 15, 2007 Share Posted November 15, 2007 A pot of Taubmans and a roller should see ya right. Quote Link to comment Share on other sites More sharing options...
mk5corty Posted November 16, 2007 Share Posted November 16, 2007 whats good for cleaning vinyl before painting it, ive used meths and thats ok but deosnt get the hard stuff. I think its mostly oily hair that causes the paint not to stick I usually go for a degreaser and water mix and a toothrbush or bigger brush if its bigger. Works mint for me, never had a problem with dye. Quote Link to comment Share on other sites More sharing options...
Requiemk Posted November 16, 2007 Share Posted November 16, 2007 How many clear coats will i need for my car? paint is dylon? Quote Link to comment Share on other sites More sharing options...
